Haas macro engraving problem
Results 1 to 7 of 7
    Nov 2018
    5
    Default Haas macro engraving problem
    My shop using mostly Haas vf mill and we have big problem with the serial number engraving portion. The machine can not make two number 0 next to each other. Like 1100 and it will alarm out. So we have to skip to the next number which is 1101 . This is very frustrated. Any body know how to fix this? Thank you. Btw it happened to all the control of haas from old to the newest one
  2. Likes tteitgen liked this post
  3. #2
    Jan 2015
    796
    120
    410
    All of the machines are wrong, hmm. Care to post come code from your program?
    May 2005
    CA
    1,174
    10
    311
    Maybe it needs a "." (point) after the second zero.
    Jul 2016
    Indiana
    323
    38
    What is the alarm?
    Nov 2018
    5
    The way we did was putting the first number and last number in offsetpage and that how the macro do the engraving. Ex : we put .1090 for the 1st part and .1100 for the last one. So when we at the last part the machine would alarm out cause 1100 has two 0 and only run 11 and stop right there without finishing the 00 . So my question is do i have to fix the number that i put in offset page or do i have to fix the macro ?
    Nov 2018
    5
    Quote Originally Posted by friesen View Post
    What is the alarm?
    Alarm said something about macro.
    Sep 2009
    PA
    1,490
    200
    422
    Quote Originally Posted by Spiros1 View Post
    While I don't know the exact macro program you a running it sounds like it may be a problem with the control reading ahead and alarming. This can cause issues with probing as well and HAAS recommends turning off look ahead for probing macros, maybe try turning it off just before the engraving.
    Here is a video explaining it. Then again it may not be your problemm at all.
    I would watch the entire thing. good tips at the end.
    Limiting Block Look-Ahead when using Macros – Haas Automation Tip of the Day - YouTube
