Haas reads past macro argument in m98 sub call
Results 1 to 5 of 5
    Dec 2019
    Ohio
    Default Haas reads past macro argument in m98 sub call
    I am using a Haas 2009 vf3 mill with a DS30-SSY
    I'm having an issues where the macro argument reads past the Z level argument to end last z move. It will not move the next line of code, and continues to go back to the N100 line. This code is embedded in a sub call. I have written many helical milling macros much like the one below all on Fanuc based machines and had no issues. On a HAAS is there conflict with using M98 P#### calls being it may want to loop back with the look ahead?
    O7001(HELICAL MILL+CBORE)
    #640= 0.927 (PIN HOLE SIZE)
    #641= -1.36 (COMPRESSION DISTANCE VALUE)
    #642= 3.917 (PISTON MAJOR O.D. VALUE)
    #643= 2.865 (LOCK RING DISTANCE)
    #644= 0.073 (LOCK RING TOOL WIDTH)
    #645= 1.007 (LOCK RING DIAMETER)
    #646= 1.250 (PIN BOSS SPACING)
    #647= 2.75 (PIN LENGTH)
    #648= 3.130 (OUTSIDE PIN BOSS)
    N778
    #630= [ [ #642 / 2 ] + 0.1 ] (Z CLEARANCE PLANE)
    #631= [ #642 / 2 ] (Z INITIAL CUT)
    #632= [ [ #643 / 2 ] - #644 ] (1RST LOCK RING Z VALUE)
    #633= [ #643 / 2 ] (2ND LOCK RING Z VALUE)
    #634= [ [ #645 - #638 ] / 2 ] (LOCK RING DIA. VALUE)
    #635= [ [ #643 / 2 ] + 0.09 ] (Z VALUE FOR CONTOUR BORES)
    #636= [ [ COS[ 45 ] ] * [ #640 / 2 ] ] (LOCATION FOR THE REMOVAL NOTCH)
    #637= [ [ #643 / 2 ] - 0.0937 ] (Z VALUE FOR NOTCH TOOL)
    (#638-DIAMETER ARGUMENT FOR LOCKRING DIAMETERS)
    #604=[[#648-#647]/2]]
    #606=#640-#605
    #607=#606/2
    #611=[#604+.05]
    N1000
    X#601Y#602
    G1Z#630F25.0
    N100
    G1Y#607 D23 F50.0
    G2J-#607 Z#631
    #631=[#631-.03]
    IF[#631GE#604]GOTO100
    G1Y#602
    G00Z#630
    IF[#651EQ0]GOTO2100
    N2000
    X#601Y#602
    G1Z#630F25.0
    N200
    G1Y[#607-.005] D23 F50.0
    G2J-[#607-.005] Z#635
    #631=[#631-.03]
    IF[#631GE#635]GOTO200
    G1Y#602
    G00Z#630
    N2100
    M99
    Sep 2006
    Long Island, New York
    660
    276
    104
    I add a G103 P1 to limit the look ahead while I run the macro, then a G103 after the macro but before the machining to reset the look ahead.
  3. Likes nrj38 liked this post
    Dec 2019
    Ohio
    Would this be the right approach adding it in the sub
    O07001 (HELICAL MILL)
    N778
    #631=ROUND[#631]
    #629=#631
    #604= [ [ #648 - #647 ] / 2 ]
    #606= #640 - #605
    #607= #606 / 2
    #611= [ #604 + 0.05 ]
    #651=1
    G103P1(TURN LOOK AHEAD OFF)
    G01 Z#630
    N10
    X#601 Y#602
    G01 Z#631 F25.
    G01 Y#607 F50.
    N100
    G02 J - #607 Z#631
    #631= [ #631 - 0.03 ]
    IF [ #631 LT #611 ] GOTO200
    IF [ #631 GE #611 ] GOTO100
    N200 G02 J - #607 Z#611
    G01 Y#602
    G00 Z#630
    IF [ #651 EQ 0 ] GOTO2100
    N20
    X#601 Y#602
    G01 Z#630 F25.
    N200
    Z#635
    G01 Y [ #607 + 0.0025 ] F50.
    G02 J - [ #607 + 0.0025 ]
    G01 Y#602
    G00 Z#630
    N2100
    G103(TURN LOOK AHEAD ON)
    M99
    Sep 2006
    660
    276
    104
    Here's a sample from the last one I did.
    I did the G103 P1 right where the program enters the macro, and turned it off once it got to machining
    Code:
    N1
    G103 P1 (LIMIT LOOK AHEAD FOR MACRO TO WORK)
    (-- MACHINE WON'T GRAPH WITH M109'S --)
    (UNCOMMENT NEXT LINE TO WATCH BACKPLOT ON SCREEN)
    (GOTO2)
    (CLEAR THE VARIABLES)
    #501= 0 (1ST CHARACTER VARIABLE)
    #502= 0 (2ND)
    #503= 0 (3RD)
    #516= 0 (Y/N INPUT FLAG)
    (GET USER INPUT)
    M109 P501 (MILL 1ST [#1-1 or P])
    M109 P502 (MILL 2ND [#0-9 or H])
    M109 P503 (MILL 2ND [#A-T])
    (LET USER VERIFY INPUT AND RUN)
    M97 P101 (SUBROUTINE TO VERIFY 1ST NUMBER INPUT)
    M97 P201 (2ND LETTER INPUT)
    M97 P301 (3RD)
    (LET USER CHANGE THEIR MIND)
    M109 P516 (Cycle Start[Y] / Start Over[N] - [Y/N])
    (GO BACK TO BEGINING IF ANSWER)
    (IS ANYTHING BUT 'Y')
    IF [ #516 NE 89 ] GOTO1
    (MAIN)
    N2
    G40 G80 G17
    (GET PROBE AND ADJUST FOR)
    (PART THICKNESS)
    T21 M6
    G53 G90 G0 X-5.64 Y-7.64
    G53 G01 Z-9.9 F400.
    G65 P9995 W54. A20. H-.3
    (CHANGE OTHER FIXTURE HEIGHTS TO NEW G54 HEIGHT)
    #5283=#5223 (G57 Z = G54 Z)
    #5263=#5223 (G56)
    #5243=#5223 (G55)
    T1 M6 (5/64" CARBIDE 4 FLUTE STUB)
    M03 S8000
    (REACTIVATE LOOK AHEAD)
    G103
    M08
    (1ST NUMBER)
    G55
    M98 P#501
    Sep 2006
    660
    276
    104
    Wherever your program enters the sub, I would have the G103 P1 be the first thing it reads.
