Taylor-WSE
- Apr 24, 2019
I'm missing something here and need some help.
All I'm trying to do is set a work offset by probing a bore. I have no problem setting an offset when I'm doing single-surface probing cycles but for some reason I'm struggling with the bore cycle. I believe my code below is correct but the machine just refuses to update the G54 X&Y offsets. I have verified macro variables 185 & 186 (X&Y position taken from P9814 cycle) are correct, they just aren't updating the work offset.
This is on a next gen control Haas VF. I'm writing the program instead of using VPS because long term I'm going to have the program level an A-Axis rotary.
My ideas...
Please let me know if you need any more information and thank you in advance for any input.
My ideas...
- Next gen 9000 programs are structured differently than classic control?
- Syntax error, maybe a decimal etc.?
Code:
O101 (Set WCS Off Bore)
(Jog probe into place)
G54
G90
G43 H31
G103 P1
G65 P9832 (Probe On)
G65 P9814 D1.5 S1 (Probe trunnion bore)
G65 P9833 (Probe Off)
M30
