Hi - I bought a 2000 Haas SL-20. I have some work to do in the shop before I can place the machine in position so thought I would learn all I could from the manuals and available videos so I am ready to go when I can finally unpack the machine. I have a Fadal VMC, so understand the basics but have no experience with a cnc lathe. With the VDI turret and a static tool holder, when using a carbide insert holder like one for a CNMG how do you adjust the tool tip height in relation to the part centerline? On my manual lathe I loosen the tool post and adjust the tool holder up and down on the tool post with the knurled nut. What is the comparable adjustment on this lathe? I have looked through all my factory manuals without finding an answer. I have plenty on info on the live tooling setup, but none on the static. Inspection of the tool holder itself did not indicate any adjustment. Shims? Wedges? Is there a stop point on the turret rotation that you set each time you change a static holder? What obvious thing am I missing? Thanks for the help - its nice to have a resource to access folks with experience.
