I tried DNC4U out a while ago and remember it sending blocks of code to my machine and then when I was running the program when I got close to the end of that block it would send another block of code. My trial period ran out and I've been using my HSMWorks Edit transmit mode. It only seems to send out the first block of code and then my machine catches up and it runs one line at a time and is jerky for short moves.
I believe my baud rate of 19200 was the same for each. (Fanuc Oi-Mate MB control btw)
So does the type of DNC determine how the data is sent to the CNC? IOW was DNC4U sending it out in nice blocks and now HSMWorks isn't?
Or perhaps did I change a setting in the Fanuc control accidentally when I was setting up the parameters for the HSMWorks? Is there such a setting that allows data to come in larger blocks?
