Haas TL3 grease fitting size
Results 1 to 2 of 2
    Jan 2014
    Montana
    83
    36
    18
    Default Haas TL3 grease fitting size
    So I am finally getting around to putting a remote grease fitting on the Z axis lead screw, so I don't have to act like a monkey to grease the thing. What size hole is the zerk fitting tapped to? It appears to be a 1/4-28, but my 14-28 adapter doesn't fit into itand I can't get a 1/4-28 tap to even start. Somebody else must have done this.Let go of your secret!
    Rob
    Jan 2014
    Montana
    83
    36
    18
    what the hell is Haas doing with metric fittings?
