GcodeInMotion
- Apr 4, 2019
This is more of a machine/maintenance issue than a machining issue.
I have a Haas UMC750SS is about 4 years old and I have the 1000PSI TSC option. I have used the TSC sporadically over the four years with out issue. I tried to use it today when drilling a hole with a CoroDrill and the pump had flow but wouldn't build pressure and eventually the machine would alarm out with 151. It seems that the pump head may be pooched. I also have the 300PSI TSC pump so I swapped them out and it worked great.
At this point I can carry on with the 300PSI pump but I'm faced with replacing/repairing the 1000 PSI pump.
First off anybody with any experience with TSC on a Haas that may have some input it would be much appreciated. Secondly if I have to replace the pump head Haas wants over 1K for the replacement head and I was thinking that there must be replacement parts/re-build kits for the pump head out there. If anyone knows whos manufacturing the pump heads for Haas it would be a step in the right direction in getting parts.
