Hey all!
Finally posting something as I cannot find the answer.
I noticed that the UMC wastes a ton of time during tool changes. It will change the tools out then it will start to rotate B/C, then move to position.
I understand that tool changes are "protected moves" for good reason, but is there a way to start axis movement while it's in tool change position?
I've tried writing the line as:
M06 T01 G00 B0 C0
It will fully finish the tool change then move as if they're on separate lines. It does the same if I have the G00 go first.
Thanks a ton in advance!
M06 T01 G00 B0 C0
