HELLO
I bought the UMC750SS and UMC1000SS a few months ago.
I started having problems with the dimensions.
Dimensions started to differ by more than 0.1.
In Korea A/S, it is said to be the correct setting, but the cause cannot be found.
The period was over a month and a half.
I want you guys to see it and judge if it's right.
https://youtu.be/AgTKnertMsw
(B:90 C:0)
(Change the button X-> SHIFT+B -> SHIFT+C)
https://youtu.be/92_Pd_eqWgc
(B:90 C:0)
https://youtu.be/9vBigN7a2_0
(B:0 C:0)
One more Question
PSI is right?
UMC750SS , UMC1000SS Year of production is 2021/03
The HAAS website says this
Applies to machines built from April 2015
UMC-750/P B axis pressure should read 800-1000 psi.
UMC-750SS B and C axes pressure should read 350-400 psi.
UMC-750 Rotary Brake - T-0062C Bleed Instructions - AD0309
(B:90 C:0)
(B:90 C:0)
(B:0 C:0)
One more Question
PSI is right?
