I have an older (1996) VF1 that I am attempting to run via DNC and I continue to get two alarms during DNC mode. The code is 850K so not large in terms of DNC programs. I have tried removing line numbers but continue to get alarms.
(1) Number Range Error - This seems to occur a different places in the code about 7 mins into the program. I did renumber the lines and it went further. Then I took all the line numbers out, but still was unable to reach the end of the program.
I am using DNC4U as the RD232 software to send the G code. It is setup using the recommended settings and we have never has a problem using this software when loading programs to the machine. The problem is only in DNC mode.
Any thoughts?
Any thoughts?
