Haas VF2 Amperage Draw?
Results 1 to 15 of 15
    Aug 2009
    Arizona USA
    553
    6
    Default Haas VF2 Amperage Draw?
    Can anyone tell me what the amperage draw for a Haas VF2 is? I've called Haas about 4 times with that question and nobody with a brain in their head is ever there to take my call. I thought I seen some where it needed to be wired to an 80 amp breaker but I am not sure how accurate that info was. If thats the case I will need at least a 30HP converter, and a phase perfect that size is not cheap. I understand the machine will draw a lot having a 20HP spindle motor. I was just considering trading my TM1 in for something with an enclosure but the cost of a phase converter alone might be a deal breaker. I dont necessarily need the added power of a VF2 but the enclosure and a chip auger would be nice. Can any one suggest another Haas machine that has an enclosure but wont take a 30HP converter?
    Apr 2009
    Midland, TX
    1,139
    288
    395
    my VF-3 is a 20 haaspower mill (with the gearbox!) and it requires a whopping 50amp breaker for its 35/40 max amp load, 3 phase.
    Jul 2009
    Peoria, IL
    11,716
    51
    8975
    My VF3 has a 40 amp breaker inside.
  4. Likes bjf5051 liked this post
    Dec 2012
    Virginia, USA
    230
    19
    161
    My 2012 VF3 has the 10k rpm inline direct drive, 30 HaasPower with a 40HP Vector Drive. The breaker on the back of the machine is 80 amps and they specify 100 amp service. I doubt it draws anywhere near that, but that is what the manual calls for - obviously this has changed over time. What year is your machine? There is a section in the back of the manual that specifies power requirements.
    Haas Downloads: Manual Updates | Haas Automation, Inc. | CNC Machine Tools
    Jun 2012
    Idaho
    3,135
    1729
    2046
    You did not specify voltage.
  7. Likes bjf5051 liked this post
  8. #6
    Sep 2007
    Orlando, FL
    295
    129
    92
    I would assume 240 if he's talking phase converter.
  9. Likes bjf5051 liked this post
  10. #7
    Jun 2012
    Idaho
    3,135
    1729
    2046
    Quote Originally Posted by kapps View Post
    You are probably right.There are however other out there.
    My machine is 440volt.I use a transformer.Our shop has 240volt 3 phase.My amperage is 1/2 of what 240 volt systems have,,just saying.
  11. Likes bjf5051 liked this post
  12. #8
    Feb 2013
    Belgrade, MT
    151
    26
    27
    We got several more machines in the last yr and one of the wanted 200 amp service (big multitasking machine) so I called the power company they told me $20 grand and I almost fell down. We already have 400 amps. Another local shop and friend said you should get a cheap amp clamp and see what you are drawing now. $80. Wow.
    Twin spindle live tooling 20hp lathe, 2 sharp sx2414sv hogging alum. (About same vf2), and I think we had one other machine on there and at peak 55 amps total coming off main feed to the box. 240v 3ph
    These companies want you to supply enough power that if you are running 10k rpm and somehow dead head stop the motor on x,y,z and spindle all at the same time, that then will trip the breaker.
    You should be fine 20-30 amp breaker
  13. Likes bjf5051 liked this post
  14. #9
    Aug 2009
    Arizona USA
    553
    6
    Ok so it looks like it just depends but anywhere from 40-80 amps. I am actually considering a new machine but that will depend on the tax advantages and what is available in the used market.
  15. Likes bjf5051 liked this post
  16. #10
    Sep 2009
    barcelona, spain
    2,388
    530
    1432
    Fwiw..
    Machine specs is one thing.
    Motor draw is quite another.
    The power drawn is proportional to the amount of metal you cut. Accelerations use full power for a short while (2 secs or so).
    I had to run some of our 8 machines off a genny last year (no power at all).
    With a 50 hp genny, we could start 4 machines at once, and run 2-3 machining *when* we ran them carefully with limited acceleration.
    And the office upstairs, with 5-6 people. Drawing about 1 machine-equivalent (with no heating. In 5C.Brrr ...)
    It was cold enough to kill penguins ("para matar penguinos ...").
    Amps depending on voltage, but kW is a measure of power. A 40 hp or 30 kW motor will need about 30 kW..
    Grin ..
    Avg cutting draw is 1/3-1/2 max power at most (so about 10-15 kW for VF2).
    Your peak loads are averaged between all machines and total building power.
    IF you manage to run at peak power for extended times, you are cuttng so much metal and should be making so much moolah all above is meaningless, and just pay someone to install more when needed.
    You are also a fantastic programmer and job planner and fixture specialist.
    Avg heavy usage of machines is 1000 hours/yr spindle-on, or 1/8 of max (unless feeding with robot).
    Of this, avg draw is about 15%.
    So, 150 hrs / 8760 == 98.13% of time spindle is idling ..
    Something to think about.
  17. #11
    Jun 2006
    Thunder Bay Canada
    1,811
    567
    304
    There was a recent comment on this board about Haas rating their spindle motor hp like shop vacs.
    Something to consider when looking at those huge breakers.
    (Maybe don't really need something so large.......?)
  18. Likes Philabuster liked this post
  19. #12
    Apr 2009
    Midland, TX
    1,139
    288
    395
    Default Re: Haas VF2 Amperage Draw?
    On my VF3 on the CE panel it has 40 amp max load, 35 largest load, 195/260 volt. Haas says to run it to a 50 amp breaker. The 50 tapers and high rpm mills will say to use a 100 amp breaker.
  20. #13
    Jul 2006
    Arizona
    4,594
    18440
    4308
    Quote Originally Posted by bellinoracing View Post
    1) Haas machines are rated like shop vacs. Can you really supply a '6hp' shop vac from a standard 120v 15amp outlet?
    2) Save up and buy the PT-380 Phase Perfect anyway. You will not outgrow it when you add more machines or get a true 30hp machine. I love my PT-380.
  21. #14
    Mar 2013
    Phoenix AZ
    54
    12
    I realize this thread is a couple of months old, but if somebody reads it hope they can add specific answers to the OP's question, similar to those posted by pvsora and drewboyer. I would like to know too what the actual electrical requirements for a current model Haas VF1/VF2 are.
    It is widely known that some manufacturers like to overstate the ratings in their machines for marketing purposes. However, they are required to provide accurate information in the machine tool identifcation nameplate on the back of the machine, so this is a reliable source of information of the machine actual ratings.
    If you have or operate a Haas VF mill, please provide:
    Machine model and year
    machine input voltage (I assume all VF mills require 3 phase electricity)
    full load amperes (a good indicator of the minimum circuit breaker size needed to run the machine under normal load conditions)
    largest load amperes (an indicator of the spindle motor size)
    size of circuit breaker in the machine electrical cabinet.
    spindle max rpm and type (belt, direct drive, gearbox/no gearbox)
  22. #15
    Nov 2019
    17
    10
    Drew, what phase converter are you using with your VF3 on your 100 amp breaker, I am looking at a VF2 which is calling out 50A. American Rotary does not have a product that works but I have seen the Phase Perfect does. Just looking for a more cost-effective solution if possible. Thanks!
