Haas VF4 4th axis
Results 1 to 3 of 3
    Jan 2020
    Wisconsin
    Default Haas VF4 4th axis
    The 4th axis on a older haasVF4 17 pin brushed motor is causing a over temp while it sits idle. It has a magmotor brushed motor and the brushes are good. The head itself doesn't seem to have any bearing issues. The motor does get very hot to the touch. Has anyone else had this problem ? I'm assuming a bad motor but it megs out fine
    Dec 2003
    poulsbo, wa, usa
    910
    67
    393
    you might check your setting in the controler? I would think the power setting change with what 4th axis you set the control up with and also any servo motor I have had dealing with runs the power up hi to move the axis then reduces the power WAY down when its just parked ,, if your power was still up it would heat up a motor fast ,,
  3. Likes saubart_ liked this post
    Aug 2007
    Idaho
    1,142
    97
    181
    I had a 5c rotary that did something like that, somewhere along the line the motor got knocked hard enough to shift it some, long story short we loosened four 10-32 screws that held the motor to the indexer, let it find its center, retightened it and it's good now.
