13engines
Stainless
- Jun 30, 2015
- Saint Paul, MN
2000 Mori SL200-SMC Fanuc 18i (Mori MSC-501)
I've asked about this problem previously and have waited to visit it again until it happened again. Today on a different program the problem re-visited.
The problem is when running in Memory Mode, at some point in a program the tool change will get as far as unlocking the turret but no further. There is MTN and FIN showing in the buffer so the Servo has been told to move and the control is waiting for a Finish Signal. The Lock Pin Out Signal has been satisfied. It will not time out either. I've let it sit for 20 minutes before and nothing. Note that in all other circumstances... bar none, the turret works perfectly fine and never ever fails. Even in Memory Mode with programs that don't have the apparent aberration that causes the problem.
I seem to have found the cure, which is the control does not like going for a tool change while in G1 and wants G0 to be called before it will cooperate. I find it a little odd as they're both Group 1 G Codes. G53 doesn't seem to satisfy the turrets needs either.
I've concluded that my programming is okay and am thinking it is a bug in the ladder. Or an incorrectly written ladder more likely. It's more of a curiosity now then anything.
Just wondering if anyone else has had this problem, and if those who know about things like this think it for sure has to be the ladder? Or something else? Next time I call Mori Seiki I might ask about a ladder fix or upgrade.
For reference here are excerpts from the two programs that both failed and their cures highlighted.
T0200(SIDE 2 TURNING)
G20G40G54G80G99
G0Z0.075T0218
X1.43
G50S3000
G96S510M3
M8
G71U0.075R0.05(ROUGH)
G71P1Q2U0.06W0.01F0.012S510
Misc Blocks
(FINISH PASS)
G0X0.645Z0.15
G1G42Z0.05F0.01
X0.8745Z-0.065
Z-2.
X1.53Z-2.1891F0.008
G40X1.73F0.015
G0Z1. (Added this one block to fix it. Brought it out of G1.)
M9
G53X0.M5
G53Z-5.5
T0600(THREADING TOOL) Here's where it used to hang.
G20G40G54G80G97G99
G0Z0.25T0606
X0.975
Misc. Blocks
M30
EXAMPLE 2
T0100(TURN)
G20G40G54G80G97G98
G0Z0.1T0101
X0.92
G50S2750
G96S1100M3
M8
G99G1Z-0.8F0.012
X1.05
G0Z0.1
X0.875
G1Z-0.8F0.01
X1.05
G0X1.2 (Added this one block to fix it. Again brought it out of G1.)
M9
G53X-3.Z-5.M5
T0500(3/16 END MILL) Here's where it would hang.
G20G40G54G80G97G98
M45(C AXIS CLAMP)
G0Z0.1T0505
Misc. Blocks.
M30
Dave
G20G40G54G80G99
G0Z0.075T0218
X1.43
G50S3000
G96S510M3
M8
Misc Blocks
(FINISH PASS)
G0X0.645Z0.15
G1G42Z0.05F0.01
X0.8745Z-0.065
Z-2.
X1.53Z-2.1891F0.008
G40X1.73F0.015
M9
G53X0.M5
G53Z-5.5
G20G40G54G80G97G99
G0Z0.25T0606
X0.975
Misc. Blocks
M30
EXAMPLE 2
T0100(TURN)
G20G40G54G80G97G98
G0Z0.1T0101
X0.92
G50S2750
G96S1100M3
M8
G99G1Z-0.8F0.012
X1.05
G0Z0.1
X0.875
G1Z-0.8F0.01
X1.05
M9
G53X-3.Z-5.M5
G20G40G54G80G97G98
M45(C AXIS CLAMP)
G0Z0.1T0505
Misc. Blocks.
M30
Dave
