hardinge superslant with gn fanuc 6tc control m code for bar feed air
Likes Likes:  0
Results 1 to 2 of 2
    Jan 2019
    Louisiana
    Default hardinge superslant with gn fanuc 6tc control m code for bar feed air
    I am looking for someone who has connected a barfeed to a hardinge superslant lathe with gn6tc control using an m code to control the air to the bar feed.is there a way to add an m code to the control? the manual has reference to a m20
    but it does not work.I am presently using the parts catcher
    valve output for the air,but it takes a few seconds to work.
    any suggestions would be appreciated.
    Jan 2019
    Missouri
    96
    26
    14
    I think it says in the manual
    "the barfeed signal is internally decoded, but external drivers are not supplied for it"
