Leadfootin
Cast Iron
- Feb 5, 2009
- London
Working on a VMC700 in the Windsor, Ontario area which had the Fanuc main controller replaced after delivery with an empty slot! It seems the PLC which reads all the various position and alarm sensors is not communicating with it. Main safety circuit is intact after a couple switch adjustments and you now have to verify door switches on start up.
Another tech had jimmied the door switches and caused numerous errors delaying me getting to this point. As well it appears the processor is not talking to the X,Y,X axis amplifiers as well as the spindle drive since all show a not ready condition. FWIW the processor communicates just fine with the control panel and CRT.
Is there a tech in the Windsor area who has both the knowledge and the required software to get this machine up and running?
Peter
Peter
