Hardinge VMC700 X,Y,Z servo alarm and hopefully photo
Likes Likes:  0
Results 1 to 7 of 7
    Feb 2009
    London, Ontario, Canada
    257
    19
    36
    Default Hardinge VMC700 X,Y,Z servo alarm and hopefully photo
    New job and a real challenge! Hardinge VMC700 with Fanuc Series 18-M controller gives 401 errors X, Y, Z axis VRDY OFF when any motion is attempted. Spindle won't run, 1015 spindle orientation fault etc. Servo amps show not ready and spindle drive has relay cycling every couple moments.
    Gets better, no lights on centre panel but traverse gives 401 errors and home button is ineffective.
    A number have techs have had their hands in this auction bought machine over the last year and the only consensus is a comm error between the panel and drives.
    Late this aft while scratching my head I decided to take a closer look in the back panel and observed the following. In the GE Fanuc PSU unit where all the cables attached was an empty slot marked PSU B1 with what looks to be a computer backplane connector at the bottom.
    Is this a cpu for the machine controls and am I looking at a substantial job to get it up and running if I can find a board?
    Jan 2014
    Washington
    4,401
    805
    2370
    Your picture is too small to see anything.
    Feb 2009
    257
    19
    36
    Just a big open slot in the controller, will try to upload a better one. Try this.
    Jan 2014
    Washington
    4,401
    805
    2370
    Your power supply PSU B1 is just missing a blanking plate to cover the hole. If your machine was configured with a PSU C then the slot is used and connected to the buss in the back.
    What status LEDs and alarm LEDs are lit, if any, on the Main board and the PSU B1 board?
    Jun 2019
    Maryland
    139
    23
    possible blown fuse in power supply.
    Feb 2009
    257
    19
    36
    No LED's or status alarms are lit, there is no PSU B1 board present. My question is should there be a board there and if so how do I determine the correct one? Servo drives are operative and just sitting idle.
    I will check machine configuration if in files, otherwise how can I check it? This machine has no communication between control panel and servos with techs telling us it was a wiring issue. However it seems larger than a broken wire issue so I am tracking down possibilities.
    Jan 2014
    Washington
    4,401
    805
    2370
    Quote Originally Posted by Leadfootin View Post
    ...... there is no PSU B1 board present. .......
    The item marked PSU B1 is the PSU B1.
