tonyconlon
- Nov 19, 2020
Hi
I'm currently running a harrison milling machine, vertical model from a 4kw chinese huanyang vfd.
the vfd is rated for 4kw and im told the milling machine has a 2 horsepower motor, indeed I removed the motor and wired it for 220v its an unusual motor, very heavy cast Iron frame and a 6 pole 900 ish rpm range if I recall
in any case the trouble im having is the machine bogs down especially when cold in the highest gear(2000rpm)
is there something im missing here because I run a harrison lathe quite easily from a vfd although the lathes max rpm is 1000 rpm or so it has no power issues and ive tried a few of my vfds and they all fail in the high gear. any Ideas?
thanks
Tony
thanks
Tony
