Has anyone here ever replaced the resistors in a Yaskawa drive?
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Oct 2011
    Western Nebraska USA
    177
    31
    98
    Default Has anyone here ever replaced the resistors in a Yaskawa drive?
    I'm fairly certain the braking resistors are burnt out on my 1999 Hurco VMC. I get a spindle load alarm fault anytime the the spindle brakes for a tool change from speeds above 2800 to 3000. If you manually reduce RPM slowly the spindle load increases but does not fault. Anyhow, we've changed resistors on Allen Bradley drives before and it isn't all that difficult, where are they located in the Yaskawa? I was wondering if anyone could give me some advice or photos. I can't tear the machine apart and leave it sit while I explore the drive and order parts. It HAS to run, even crippled. The drive is a Yaskawa Varispeed 626VM3, Model# CIMR-VMW27P5
    Jan 2008
    Canada
    345
    10
    32
    Do you know the exact error code it shows?
    Apr 2005
    Beaverdam, Virginia
    7,489
    709
    3541
    I have the exact same spindle drive on a Kitamura that is down for a bad power supply. Pretty sure you have the same set-up. What does the alarm say exactly? If you have the same set-up there will be a braking unit in the system that bleeds off the DC bus spikes, that unit is external to the spindle drive. My braking resistors are connected to the braking unit but remotely located under a cover on the side of the machine. They are bigger than road flares and can be easily checked with a meter. Those rarely go bad, it could be the braking unit itself. Most of them have a light that comes on when they are working, mine failed years ago and had to be replaced.
    Wish I could help you with photos, but on crutches and pretty immobile for a few more days.
    Oct 2011
    177
    31
    98
    I'm not in the shop right now but I believe it's F400 Inverter over voltage fault
    Oct 2011
    177
    31
    98
    Quote Originally Posted by Dualkit View Post
    I looked for an external set-up but I didn't see one. That doesn't mean there isn't one however, I very well could have overlooked it.
    Mar 2007
    Bellingham, WA
    166
    10
    12
    Does the drive have main terminals marked "B1/P" and "B2" (or something like that), probably in between the incoming power (R, S, T) and outgoing motor (U, V, W) terminals? If so, do the "B" terminals have wires on them? If so, follow those wires and you will find your braking unit or braking resistor.
    Oct 2011
    177
    31
    98
    I will look again this afternoon. I haven't had this machine very long and it has done it since we got it. I do allot of stainless so I've just been using it as is while I researched it. I however got a new customer who has allot of Aluminum and mild steel and it's become urgent. I am wondering if it was even possible that these drives came with internal resistors? Were there external ones that were removed? I don't know. What I really need is drive schematic for that model drive. I bought the machine from a used eq. dealer so they will be no help.
    Another question...I have a 15hp Allen Bradley PowerFlex 755 drive that I bought a couple years ago for a project that never materialized. Has anyone hear ever subbed out a Yaskawa spindle drive for a different brand. I was wondering if it's even possible.
    Apr 2005
    Beaverdam, Virginia
    7,489
    709
    3541
    Sorry that I can't hobble to the shop and check but I believe MLeonard is correct about those wire markings, it rings a bell. If the problem only occurs when decelerating the spindle your culprit is not the spindle drive. I had the exact same same happen to me with the exact same drive. The spindle drive is connected to the braking unit that is probably 1/2 the size of a shoe box, it could be outside the main cabinet under a cover. While the braking unit has some resistors and a heat sink inside it is connected to a large resistor rack that can be anywhere away from the braking unit itself. Those resistors are usually inside a side pocket with a grated cover over them as they can get rather hot. My guess is the braking unit has failed and it isn't engaging the resistor rack when it should.
    If you don't have a manual on the Varispeed they are available from Yaskawa for free download. There is a lot of diagnostics that you can view, you will be able to quickly figure out where the over voltage is. I am pretty sure your Varispeed is fine which is good because they are expensive, something it is connected to is causing the problem, my vote goes for the braking unit.
    Oct 2011
    177
    31
    98
    I looked over the machine up and down and can't find an external braking resistor nor any specific terminals on the drive. I'm beginning to believe that they are internal to the drive. If they are does anyone know where they are located and or what they look like?
    Jan 2008
    Canada
    345
    10
    32
    Can you post a pic of the drive terminals?
  11. #11
    Oct 2011
    177
    31
    98
    Here's a few pics I took last night. Any help is appreciated
    Attached Thumbnails Attached Thumbnails 20141203_161114.jpg   20141009_224739.jpg   20141203_161124.jpg   20141203_161132.jpg
  12. #12
    Sep 2006
    Abingdon, VA
    3,397
    4579
    3171
    One or more of the main power transistors could be failing as well. These are located under the main circuit board, looks like there is 6 of them. They not only "create" the power to go out to the spindle motor, but they manage the power coming back in when the motor is decelerating.
    You can find them on ebay, as well as several Yaskawa spindle drives as well.
    Good luck with it.
    ToolCat
  13. #13
    Apr 2005
    Beaverdam, Virginia
    7,489
    709
    3541
    Quote Originally Posted by rb07565 View Post
    I thought your Varispeed number looks familiar, but maybe mine is different, I am still too gimpy to go out and look. Yaskawa had something called a descriptive manual for a 626vm3 on their website for the F-400 alarm that trouble shooting guide gave basically only two things outside of wrong settings and your settings have to be fine.
    Main contactor failure which basically would be bad contacts or coil problems causing improper voltage across the phases, not likely or get this "controller failure." To me along with your wiring set-up the braking system is self contained like you thought. Their are a few other manuals on a 626vm3 with an extra letter in it on the Yaskawa website, check them out they might fit yours. If I were you I would take the top board off and just look underneath at the next board, you might find something obvious.
  14. #14
    Oct 2011
    177
    31
    98
    Another check that slipped through the cracks. I'm running this thing on a roto-phase so I'm going to check the incoming voltage. According to Yaskawa if the incoming voltage is way too high or too low it can cause the drive to throw an F400 error during deceleration. Anyone run into this? If so what's the tolerance for incoming voltage phase to phase?
  15. #15
    Oct 2011
    177
    31
    98
    I was typing the most recent reply at the same time you were. I'm going to check the incoming voltage this afternoon with a meter that will track spikes.
  16. #16
    Mar 2007
    Bellingham, WA
    166
    10
    12
    The terminals I quoted for external brake connection were for a 626-VM3C (found on Bridgeport Torq-Cut machines). I see now that yours is different.
    Look on www.yaskawa.com for manual SIE-S626-6C.
    Page 36 of that manual says "Braking Method: Regenerative brake with power regenerative function".
    I think that may mean that it regenerates to the AC service lines instead of dumping power to resistors. If so, that may not play well with a rotary phase converter.
  17. #17
    Apr 2005
    Beaverdam, Virginia
    7,489
    709
    3541
    When mine was running off a rotary also I was in the low 230's which was on the high side. The only thing I remember having an incoming setting was the braking unit. I think my Varispeed is probably that C model that Mleonard was mentioning that is why the number looked familiar. Read the manual, mine actually has a way to have the different voltages displayed on the digital read out, that is how I determined the braking unit wasn't working.
    There could be voltages internal to the Varispeed that would be hard to meter. Maybe there is also a setting if you have incoming voltages on the high side. Also your rotary's output is going to vary with load. It will be higher when it isn't connected to a running machine.
  18. #18
    Jan 2008
    Canada
    345
    10
    32
    Quote Originally Posted by MLeonard View Post
    the OP needs to tell us if this is new behaviour or if this is a new to him machine
  19. #19
    Oct 2011
    177
    31
    98
    Quote Originally Posted by legendboy View Post
    It's done it since I got it. I haven't had this one that long. See post #7
  20. #20
    Oct 2011
    177
    31
    98
    UPDATE... It turns out it wasn't the resistors or the drive at all. I measured the voltage coming from the rotary phase converter and L3 to L2 was measuring almost 270!! WAY HIGH. I unhooked some of the capacitors until the voltage measured a normal level across all legs. I haven't had any spindle faults so far. I will keep the thread updated if there are anymore problems. Thanks for the help
  21. Likes TeachMePlease liked this post
