Has anyone here ever replaced the resistors in a Yaskawa drive? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Aug 2018
    INDIA
    9
    Quote Originally Posted by cnctoolcat View Post
    One or more of the main power transistors could be failing as well. These are located under the main circuit board, looks like there is 6 of them. They not only "create" the power to go out to the spindle motor, but they manage the power coming back in when the motor is decelerating.
    You can find them on ebay, as well as several Yaskawa spindle drives as well.
    Good luck with it.
    ToolCat
    Does any one know what could be stopping my yaskawa drive from starting?
    I recently purchased a Yaskawa 626 vm3 drive and now the spindle wont run.
    no alarms no apparent faults and i press cycle start and the program runs fine with the x & z axes working fine. the spindle forward button lights up when you press it but no spindle rotation.
    on the digital keypad on the drive the stop light is on all the time, i wonder if the repairer has stopped the unit from working for testing purposes.
    cheers guys.
    Sent from my Moto G (5) Plus using Tapatalk
  2. #22
    Jan 2014
    Washington
    4,688
    848
    2546
    Did you load the drive operating parameter data? Wired it correctly?
  3. #23
    Aug 2018
    INDIA
    9
    As per machine tool builder manual i loaded the parameter.
    The spindle is not running. Installed new Yaskawa drive. The drive always in stop mode. I try to run in jog mode it's working fine but while Spindle command given it's not working. Only forward light ON spindle is not rotating. In Magnetic contactor +24v , CC cable two cable was coming from 3CN connector both the cable was 24v DC output coming. I dismantled the contactor and checked outside it's working fine.
  4. #24
    Jun 2019
    Maryland
    308
    44
    did you check to see if you have your analog input to the drive, and if the scale in your parameters is correct? normally 5 vdc is full speed forward,-5.vdc is full speed reverse. could be your connection is bad or connector is damaged?
  5. #25
    Jan 2014
    Washington
    4,688
    848
    2546
    Quote Originally Posted by harishmech10 View Post
    In the drive or the CNC?
    Is the replacement drive just like the original? What failed on the original that made you replace it? If it was some kind of catastrophic failure, that could have damaged the CNC I/O for the run signals. What CNC control do you have?
  6. Likes harishmech10 liked this post
  7. #26
    Jun 2013
    Washington
    85
    15
    Mildly off topic but anyway ... nice pictures...actually nicely scaled and in focus. :-)
  8. #27
    Aug 2018
    INDIA
    9
    Control card was the problem. We just purchased new drive and try to install.
    CONTROL MODEL : Fanuc FS-16TA.
  9. #28
    Aug 2018
    INDIA
    9
    Quote Originally Posted by Hoss710 View Post
    I'm handling new to Yaskawa drive. Could u tell little bit brief.
  10. #29
    Jan 2014
    Washington
    4,688
    848
    2546
    Is the new drive just like the old? Not real common to use a Yaskawa spindle drive on a machine with Fanuc CNC.
  11. Likes harishmech10 liked this post
  12. #30
    Aug 2018
    INDIA
    9
    Yes new drive only. Because Yaskawa spindle motor is using in our machine
  13. #31
    Aug 2018
    INDIA
    9
    Pls suggest us to solve the issue
