Has anyone tried making a homebrew T\T rotary table using 2 4th setups?
Likes Likes:  0
Results 1 to 3 of 3
    Jul 2008
    Milverton, Ontario, Canada
    692
    200
    306
    Default Has anyone tried making a homebrew T\T rotary table using 2 4th setups?
    I have 2 Fadals here, each with a 4th. One is a large Koma unit, the other the smaller fadal one (6")
    Cash is a little tight, and I have some spare time.
    Im thinking about making a trunnion for the Koma, and mounting the 6" Fadal rotary on it.
    Use this setup as a 5 axis.
    All I'd need is an additional wiring harness. I have a spare amp here, and just switch the axis card from one machine over.
    I dont see why this wouldnt work, so long as I can set rotary ratio parameters correctly.
    Opinions?
    Jan 2019
    Arizona
    808
    74
    281
    sre you talking 5 axis full or 4 axis positioning? for positioning used it all the time on acrolocs and fadals on the haas since I have full 4th I have bolted a indexer to the 210 rotary for full 4th and positioning on the indexer.
    Jul 2008
    692
    200
    306
    Thinking it should be functional as a full 5.
    Even if 4+1 i could settle for that.
