Having Lathe drilling trouble...help please
Results 1 to 8 of 8
    Sep 2020
    Default Having Lathe drilling trouble...help please
    4mm drill keeps breaking/gilding up while cutting aluminum. Using a hs coated drill going 1.428 in deep. Running a Swiss tornos lathe with max rpm of 8000. The feeds and speeds I caluculated were s6080 f.029ipm. Using oil based milpro coolant. Any suggestions or tips would be appreciated. Thank you.
    May 2019
    Michigan
    2,269
    1066
    1534
    Quote Originally Posted by Ironcity View Post
    Something isn't adding up.
    If you're running 6080 RPM and 0.029" per revolution, yeah...I know why you're breaking drills. If your feedrate is 0.029" per minute.......you're making mouse fart dust at 0.0000047 IPR.
  3. Likes toolsteel, Fancuku, Ox, Bobw liked this post
    Nov 2012
    Wisconsin
    2,189
    3617
    2725
    What is the coating?
    AlTiN.....would be a bad idea.
    Any coatings with AlXXX in its description....= no good
    Nov 2012
    Wisconsin
    2,189
    3617
    2725
    Not exactly related to your issue.....
    I am not very familiar with swiss or that particular machine......if the hole is on center and you have live tooling using the live head and turning spindle in simultaneous mode will improve center location and size.
  6. Likes Ox liked this post
  7. #5
    Oct 2009
    Washington
    1,476
    713
    816
    What is your peck depth? Your feed is kind of light. I'm guessing you're not making drill chips but glitter instead, and it's packing into the flutes and clogging stuff up.
  8. #6
    Sep 2007
    Washington
    5,527
    246
    1750
    Thru coolant drills?
    Peck parameters?
    And yes, what's up with your feed parameter? Is that IpM, IpR, MMpR? something else?
    Regards.
    Mike
  9. #7
    Jan 2019
    180
    15
    34
    OP may have edited his post without replying, but it says f.029ipm for me.
    Sent from my SM-G955U using Tapatalk
  10. #8
    May 2019
    Michigan
    2,269
    1066
    1534
    Quote Originally Posted by sirAIG View Post
    It was there all along.
    If it really is that slow..........he's nuts. It would take 49 minutes to drill that hole. In aluminum.
    Maybe he means inches per millimeter............wait, that makes no sense............inches per millisecond??? Or does it mean idiots per machine??
  11. Likes digger doug, toolsteel liked this post
