4mm drill keeps breaking/gilding up while cutting aluminum. Using a hs coated drill going 1.428 in deep. Running a Swiss tornos lathe with max rpm of 8000. The feeds and speeds I caluculated were s6080 f.029ipm. Using oil based milpro coolant. Any suggestions or tips would be appreciated. Thank you.
