Heat shrink holders and balancers
Results 1 to 7 of 7
    Sep 2016
    Tennessee
    39
    35
    14
    Default Heat shrink holders and balancers
    How many of you that use heat shrink holders also balance your tools? We run our finishing tools (6mm,4mm,2mm,1mm ball nose) at 20,000 rpm. We are having issues with surface finish on our Makino F5, and one of the things the techs recommended was balancing our tools. Makino is also recommending we replace our spindle, which we are probably going to do. This thing has been running 2 10 hour shifts for about 4 years, and has survived a few crashes. We are cutting forge dies made from FX material on this machine.
    Nov 2006
    Montco, PA
    556
    46
    68
    We have a Schenck balancer on order but no experience with one yet. Quite a bit cheaper than Haimer and Zoller.
    What is FX material?
  3. Likes primeholy liked this post
    Nov 2005
    Illinois
    2,099
    216
    1762
    Send us the holders. We can quote just spinning them and letting you know what the GMM is, and verifying if you have a balance issue or not.
    Also we can spin them and also balance them. If its a tool that runs for a long time without replacing then we can balance with the tool in the tool holder. Most of the time we drill holes in the flange area.
    Nov 2014
    Florida
    4,524
    1739
    2168
    Quote Originally Posted by G-Auto View Post
    If memory serves, it is real shit!
    OP, isn't it the same (maybe a trade name?) as finkel (spelling?)
    Nov 2014
    Florida
    4,524
    1739
    2168
    Could be more than blance issues too. Are you using high end controlled radius ball end mills?
    Sep 2016
    Tennessee
    39
    35
    14
    Yeah, its made by finkl.
    Die Steel - Finkl Steel
    https://www.finkl.com/wp-content/upl...X_EN_feb18.pdf
    Oct 2007
    South West Canada
    2,163
    449
    Are you using very long holders? What type of shrink fits are you using and at what gauge lenghts? What brand and mfg of cutting tools are you using.
    I've found with the F5, and short heat shrink holders of good quality, along with high end cutting tools (Union, OSG, Emuge etc) that there isn't much need to balance the tools even when running 20k for hours on end.
    Your spindle may very well be pooched from the crashes.
  9. Likes 5 axis Fidia guy liked this post
