dstryr
- Jan 22, 2010
- Nampa Idaho
Am I the only one fighting this issue in extended stick out because the industry standard tool lengths are too long for the bore depths in the heat shrink tooling?
What are you using to cut them off?
I noticed that also. I plan on making all of my heat shrink holders without a stop. An optional stop will be available at additional cost that will lock in from the back and have a locking set screw. Coolant thru is possible in both configurations.
So cut with this or a like from other places.
McMaster-Carr
4571A91, you should get a few thousand pieces off of one wheel if used wet or slow and misted.
Maybe people should offer this as a service.
Bob
Frank, we ruin a couple heat shrinks a month, usually through broken end mills that either we cannot remove from the holder (1/8" - 1/4") or they wipe out the bore when the e/m breaks. Before anyone flames me for the breakage comment, most of these are broken cutting 15-5, 17-4, 347 and 440C, and once in a blue moon do we loose a 1/8" holder that has been cutting aluminum for a couple of months. Yes, we do use tool life in the controls, but these materials tend to be a bit more unforgiving than 6061. This along with just adding more tools to the tool crib, we would like a little better option than currently available from a cost standpoint. How soon do you plan on having the heat shrink holders to market?
Steve
Can I ask the silly question - If this is such an ongoing PITA, why not use a different toolholder with a deeper insertion depth? I've seen sone pretty slim hydraulic holders if the cuts aren't that heavy. Are milling chucks too long & large in body diameter?
Tile saw with an old 10" blade. Not pretty but fast, cheap, and what I have around. Usually used to cut stone.What are you using to cut them off?
I would get rid of your 1/8 shank endmill tooling and use tooling thats on a 3/16 or 1/4 shank. I use a ton of Destiny Minature tools and the tool life increase is well worth it + heat shrinking 1/8 holders is a giant PITA!
Notice
