hectical interpreplation question
Results 1 to 9 of 9
    Apr 2016
    Tennessee
    167
    135
    22
    Default hectical interpreplation question
    A bit new to hectical interpreplation or tornado milling a starter hole into aluminum and have question.
    Wouldn't a clockwise rotation tool path be more free cutting and easier on the tool than going in a counter clockwise tool path?
    May 2017
    Minnesota
    1,894
    2538
    1295
    It depends on the endmill diameter, hole diameter, feed, and speed. If you climb mill with a fast feed and a large endmill in a small hole you can exceed the flank angle of the endmill, essentially pushing the flute sideways into the material rather than slicing. Mastercam defaults to conventional milling for helical entries.
  3. Likes edge22, snowshooze, TeachMePlease liked this post
    Nov 2015
    Colorado
    390
    63
    196
    Interesting. I always got annoyed at Mastercam for doing conventional entry motion so I switched my defaults to climb. My entry parameters are quite mild tho...2 degree entry ramp and usually 60% feed rate.
    Maybe ill run a side by side comparison to see which method sounds better and cuts better.
  5. Likes edge22, mhajicek liked this post
  6. #4
    Aug 2005
    CT
    8,368
    457
    2231
    Quote Originally Posted by edge22 View Post
    Well, that's either funny, or I need to be edumacated.
  7. #5
    Apr 2016
    Tennessee
    167
    135
    22
    Thanks for the reply smart ass. A bit of a typo on my part.
  8. #6
    Aug 2005
    CT
    8,368
    457
    2231
    A bit you say?
    Twice ( in the title AND the subject )?
    So what does the word "interpreplation" mean?
    Also twice! ( had to cut/paste that one as I can't even pronounce it )
    With all that said...
    I usually prefer counter clockwise as that resembles climb cut.
  9. Likes TeachMePlease liked this post
  10. #7
    May 2005
    Ohio
    433
    21
    125
    Hectic is defined as "characterized by intense agitation, excitement, confused and rapid movement, etc."
    So...I guess I have used hectical cutting paths when I forgot a G1 or misplaced a decimal in my feed rate
  11. Likes TeachMePlease liked this post
  12. #8
    Dec 2012
    Se Ma USA
    2,244
    180
    1220
    Quote Originally Posted by SeymourDumore View Post
    A bit you say?
    I think that is a medical term for a procedure done just before a colonoscopy.
  13. #9
    May 2017
    Minnesota
    1,894
    2538
    1295
    I'm still working on my heretical interpolation routine; it epicycles widdershins.
