Heidenhain -can you increase the spindle RPM in a program without a tool cal?
Results 1 to 9 of 9
    Feb 2006
    Ontario, Canada
    819
    36
    108
    Default Heidenhain -can you increase the spindle RPM in a program without a tool cal?
    We are attempting to write a wash program using a spindle mounted fan. The fan is supposed to start at 2000 RPM and then ramp up to 8000 RPM maximum. However, if I put a higher spindle speed in with a tool call (to the same tool) the spindle stops for a half second before starting up again. That defeats the purpose of ramping up the RPM. Is there a way in Heidenhain code to add a higher spindle RPM without the spindle briefly stopping?
    Dan
    Mar 2007
    Wisconsin
    156
    14
    58
    Short answer; yes, it can be done.
    Longer answer; without knowing the machinie, spindle, drive, ETC. I'm going to guess the pause you are seeing is the spindle changing gears for a different range. Or, rather than gears, a different winding for different RPM range. That last bit might not be worded correctly but its about like that. I'm a machinist, not an electrical Eng.
    Try a different jump, like 1000 to 2000 and see if there is a dwell. You might find that 0 to 8000 RPM is the same "gear" and 8000 an up is another. So going from 1000 to 7000 would be no pause.
  3. Likes gustafson, toolmaker96 liked this post
    Sep 2002
    People's Republic
    3,740
    328
    2397
    Yeah, I don't think it is the control, my DMG has a pause at a certain speed[it escapes me where, mebbee 5k] as mentioned above.
    Feb 2004
    Napa, CA
    2,626
    44
    695
    I was under the impression that what exactly happens at a tool call is MTB dependent. On an HH control, you can execute a tool call with only speed as a parameter, no tool number, feed, etc. On a well written PLC, this should just change the spindle speed and nothing else. On a poorly written PLC, any tool call may do a number of things like stop and start the spindle.
    TOOL CALL S8000
    should just change the spindle speed to 8000 rpm. If you have feed, tool numbers, axis etc in there, its more likely that the PLC dealing with the tool call will stop the spindle. Of course a well written PLC will stop the spindle to change gears, if that is required.
    Feb 2006
    Ontario, Canada
    819
    36
    108
    Thanks for the responses. It's a Hermle so I'm guessing it's a well written PLC. :-)
    I've also discovered since asking this question, that you can ramp up the RPM with variables.
    I'm going to try the TOOL CALL S8000 as it is a simple solution, but if that doesn't work I will play with the variables.
    2 Q10 = 50 ; Tool Number
    3 L X+0 Y+0 R0 F5000 M92
    4 L C+0 A+0 R0 F5000 M126 M92
    5 TOOL CALL Q10 Z
    6 Q1 = 1000 ;Spindle Speed
    7 LBL 1
    8 TOOL CALL Q10 Z SQ1
    9 L M3
    10 L Z-150 R0 F5000 M92
    11 L Z+0 A+30 R0 F5000 M92
    12 L X+399 A+0 R0 M92
    13 L X+0 Y-750 C+180 R0 M92
    14 L X-350 Y+0 C+0 R0 M92
    15 L X+0 A-30 R0 M92
    16 Q1 = Q1 + 1000
    17 CALL LBL 1 REP15 ; Sub Reps
    Mar 2007
    Wisconsin
    156
    14
    58
    Hermle, yes, spindle winding issue. Like a high and low. After a certain RPM, it changes how power is delivered to the motor. Like at 6000 or 8000.
    So, from 2000 to 4000, no pause. 5999 to 6000 (or what ever) pause.
    Feb 2006
    Ontario, Canada
    819
    36
    108
    You are correct. 6000 RPM.
    Dan
  9. #8
    Jun 2006
    Near Seattle
    4,821
    3208
    1331
    I think you want line 8 to be TOOL CALL Q1 rather than Q10
  10. #9
    Feb 2006
    Ontario, Canada
    819
    36
    108
    Q10 is defined as 50. That's the tool number. Q1 is the speed.
    It doesn't matter anyway, because even stepping up the RPM in this manner has the spindle stop when it hits 6000.
    For now we are maxing the fan at 5999 RPM, but we're going to go with a solid fan that can start above 6000 RPM.
    Dan
  11. Likes bryan_machine liked this post
