nordlichtFanuc
- Feb 21, 2018
Hi all
I have a simple question, but cannost seem to find the answer in the manual and I really dont know this Heidenhain Conversational stuff very good.
In automatic programm execution mode, is there a way, that I can just stop the programm execution it this point, without disabling the spindle and resetting the programm counter to start?
Our Fehlmann Picomax 51 has this control.
All I want is the machine to move to a target position, turn on the spindle.. Then the operator needs to drill a hole with the manual quill, then press start again, which lets the programm run to the next position...
Infact, I just need an M01 command equivalent on this control, but cant seem to find it, as the list in the manual only list M00 and M02, both of which turn off the spindle..
In single step mode, the operator does need to press to start button multiple times at the beginning of the programm, untill the positioning can start, due to Tool length definition lines at the beginning of the programm. This is annoying and takes a lot of time..
So Im looking for a way, to use the automatic mode, but just pause after the positioning moves.
Hope I explained clearly what our goal is
Thanks for any hint!
