Well gentlemen, it turns out that I was able to communicate with the people of Heidenhain and they provided me with a list of the materials that this power supply carries. I hope someone here will serve as it served me:
Flat head screw M3.00x6.00 DIN EN ISO 7045-A2-70 .. H .
Flat head screw M3.00x10.00 DIN EN ISO 7045-A2 .. H ..
Hex nut M 3.00x2.40-DIN EN ISO 4032
Spring washer 3.00 G .. A2
Spacer 11.40x 4.80-PA
spacer bolt 05 M3 /M.. A= 5.00
holder TO-220
Heat sink .. 0.0 .. .. 0.00x 0.00x 0.00 ..
label F 2.5 A 13.00x3.00 01
label F 4 A 13
Plug connector M ang 2 Sn 1 THT 2.540 .. .. ..
Solder pin M 1 THT str 0.000 Sn 0.00-0.00 in rows ..
Cable har 13 0.75 920 .. .. 4VL001 91B009 ..
Microfuse 5x20 F 2.5A .. ..
Microfuse 5x20 F 4A .. ..
Fuse holder 5x20 axial THT 1 ..
Spacer washer 8.89x 0.00x 2.79-PP -..
Spacer washer 6.35x 0.00x 3.18-PP -..
Heat sink 170.90x 26.00x 0.20mm GY -60 /+180°C ..
Potentiometer TRIMM Cermet 0.5W THT 100.00 kOhm 20% 250ppm ..
Resistor axial 2W 100.00 mOhm 10% 120ppm THT ..
Resistor axial 2W 150.00 mOhm 10% 120ppm THT ..
Resistor axial 0.15W 8.20 Ohm 5% .. THT ..
Resistor axial 0.35W 8.25 Ohm 1% 50ppm THT ..
Resistor axial 0.15W 15.00 Ohm 5% .. THT ..
Resistor axial 0.35W 15.40 Ohm 1% 50ppm THT ..
Resistor axial 0.15W 22.00 Ohm 5% .. THT ..
Resistor axial 0.35W 22.10 Ohm 1% 50ppm THT ..
Resistor axial 0.15W 27.00 Ohm 5% .. THT ..
Resistor axial 0.35W 27.40 Ohm 1% 50ppm THT ..
Resistor axial 0.15W 100.00 Ohm 5% .. THT ..
Resistor axial 0.35W 100.00 Ohm 1% 50ppm THT ..
Resistor axial 0.15W 180.00 Ohm 5% .. THT ..
Resistor axial 0.15W 220.00 Ohm 5% .. THT ..
Resistor axial 0.35W 221.00 Ohm 1% 50ppm THT ..
Resistor axial 0.15W 330.00 Ohm 5% .. THT ..
Resistor axial 0.35W 332.00 Ohm 1% 50ppm THT ..
Resistor axial 0.15W 680.00 Ohm 5% .. THT ..
Resistor axial 0.15W 820.00 Ohm 5% .. THT ..
Resistor axial 0.15W 1.00 kOhm 5% .. THT ..
Resistor axial 0.35W 1.00 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 1.80 kOhm 5% .. THT ..
Resistor axial 0.35W 1.82 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 2.20 kOhm 5% .. THT ..
Resistor axial 0.35W 2.21 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 2.70 kOhm 5% .. THT ..
Resistor axial 0.35W 2.74 kOhm 1% 50ppm THT ..
Resistor axial 0.35W 3.32 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 4.70 kOhm 5% .. THT ..
Resistor axial 0.35W 4.75 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 6.80 kOhm 5% .. THT ..
Resistor axial 0.15W 10.00 kOhm 5% .. THT ..
Resistor axial 0.35W 10.00 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 15.00 kOhm 5% .. THT ..
Resistor axial 0.35W 15.00 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 27.00 kOhm 5% .. THT ..
Resistor axial 0.35W 27.40 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 33.00 kOhm 5% .. THT ..
Resistor axial 0.35W 33.20 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 68.00 kOhm 5% .. THT ..
Resistor axial 0.35W 68.10 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 100.00 kOhm 5% .. THT ..
Resistor axial 0.35W 100.00 kOhm 1% 50ppm THT ..
Resistor axial 0.15W 680.00 kOhm 5% .. THT ..
Resistor axial 0.35W 150.00 kOhm 1% 50ppm THT ..
Resistor axial 0.35W 191.00 Ohm 1% 50ppm THT ..
Resistor axial 0.35W 4.99 kOhm 1% 50ppm THT ..
Resistor axial 0.35W 14.70 kOhm 1% 50ppm THT ..
Resistor axial 0.35W 18.70 kOhm 1% 50ppm THT ..
Resistor axial 0.35W 35.70 kOhm 1% 50ppm THT ..
Resistor axial 0.35W 47.50 kOhm 1% 50ppm THT ..
Resistor axial 0.35W 2.43 kOhm 1% 50ppm THT ..
Capacitor radial 3.30µF 25V- THT Aluminum +-20% ..
Capacitor radial 6.80µF 16V- THT Aluminum +-20% ..
Capacitor radial 220.00µF 63V- THT Aluminum -10/+50% ..
Capacitor radial 220.00µF 63V- THT Aluminum +-20% ..
Capacitor radial 1.00mF 16V- THT Aluminum -10/+50% ..
Capacitor radial 1.00mF 25V- THT Aluminum +-20% ..
Capacitor radial 1.00mF 25V- THT Aluminum -10/+50% ..
Capacitor radial 100.00pF 63V- THT .. +-2% ..
Capacitor radial 1.00nF 63V- THT .. +-10% ..
Capacitor radial 4.70nF 63V- THT MKT +-10% ..
Capacitor radial 10.00nF 100V- THT MKT +-5% ..
Capacitor radial 22.00nF 63V- THT MKT +-10% ..
Capacitor radial 100.00nF 63V- THT MKT +-10% ..
Capacitor radial 470.00nF 63V- THT MKT +-10% ..
Capacitor radial 100.00nF 160V- THT MKT +-20% ..
Capacitor radial 1.00nF 160V- THT .. +-20% ..
Damping pearl L = 3 mm ..
BV15573 Drossel
Inductor .. .. 1x155.00µH THT 0.00.. . 0. . . .. 0003
EMI sup. choke 01 01 1x 0.00.. THT 0.00.. N 0. . . .. ..
Rectifier diode 1N4003 THT DO-41 1.000A 200V ..
Rectifier diode 1N4448 THT DO-35 0.150A 75V ..
Overvoltage protection diode DO-13 THT 1N5649A 47.0V 5pct
Rectifier diode BYV79-100 THT TO-220AC 14.000A 100V ..
Rectifier diode BYW29-200 THT TO-220AC 7.000A 200V ..
Zenerdiode BZX79/B3V3 DO-35 THT 3.30V 2pct
Zenerdiode ZPD6
Zenerdiode ZPD12 DO-35 THT 12.00V 6pct
LED D3 GN THT .. 1 0.025A
LED D2 GN THT .. 5 0.000A
transistor 2N1893 THT TO-39 0.500A 80V .. Qty 2
transistor BCY58IX THT TO-18 0.200A 32V .. Qty 1
transistor BCY79VIII THT TO-18 0.200A 45V .. Qty 4
transistor D44H8 THT TO-220AB 10.000A 60V .. Qty 1
Transistor ZTX750L THT SO-97 2.000A 45V .. Qty1
IC LM339N DIL14/3 0 +70 THT Qty 1
IC MC7812CT TO-220 0 X THT .. Qty 1
IC MC7912CT TO-220 0 .. THT .. Qty 1
IC UC3524AN DIL16/3 0 +70 THT Qty 1
Thyristor 1-phase TO-220 THT 25.000A 100V .. Qty 1
