the spin doctor
Cast Iron
- Jul 15, 2004
- oklahoma city, ok
Very frustrated trying to understand how to set fixture offsets on this machine! The control is not behaving as I would expect from the descriptions in the manual. Using ISO G code. I assume that G247
Q339=3 should pull the X Y & Z offsets from line 3 of the active DATUM table. I thought G247 interprets coordinates referenced to the machine datum. However, it is not working. When I run a simple program, it comes up with coordinates beyond the machine limits. How to turn off any prior active Datum so it references Machine Datum. Maybe start all programs with M142 to remove coordinate transformations that are modal? I thought coordinate transformations were turned off by M30 or starting a program? Not on this machine... There might be a user parameter to remember the last datum after a program run. Not making sense to me!
