Hi guys, hoping someone can offer some advice!
Have been looking at this drawbar today as the run out is getting worse and you can easilly pry between the spindle nose and tool holder flange, which seems to indicate the pulling force is pretty weak.
This drawbar arrangement seems different to others, looks like it has to come out of the top. I have attached a drawing.
I undid the top nut (7) and removed the actuator sleeve (6), but all you are left with is the top of the drawbar.
This is flanged at the top to push down on the washer stack, so can't be withdrawn from the bottom.
There is a 5mm hex up inside the spindle from underneath, which attaches the ball collet to the drawbar - but trying to undo this is just turning the drawbar. Unfortunately there is nothing to hold onto on top of drawbar
So I put it all back together and operated the air/oil actuator to put some pressure on the drawbar in the hope it would stop it from turning.
Holding the unclamp button, the locking screw (14) now has some resistance, but it is very very tight.
So tight i'm worried it will ring off.
So before I carry on and give it some more stick, has anyone had these type of drawbar apart before? Am I on the right track?
Any chance the collet lock screw could be LH thread??
Really appreciate some help - thanks!
