twabscs
- May 7, 2012
- NW Missouri
Hi All,
Trying to quote a new part, see diagram. I would like to use flat stock to save on material. I have a good mill and lathe with live tooling to drill the holes. My quandary is how I might fixture this on the lathe to turn the diameter as it is has some tight features for o-rings, etc. Once the tight features are completed on the lathe, I'll cut the profile on the mill. Any thoughts on a good way to fixture this. It's only 3/4 thick and is basically a cap with an oring groove.
