Hello,
I have an old Kitamura MyCenter 2 with a FANUC 6m that I have been piddling around and restoring over the last couple years. I used to program this machine 15yr ago and the owner lost interest in it when it wouldn't fire up one day. Got it for the cost of rigging.
Well, after re-flowing all the boards, testing/replacing caps/resitors IC's etc, the machine is back operational with the exception of the spindle rotating via NC inputs. I can jump the ice cube relay on the spindle drive board and the spindle goes max speed, reverse (~200v on the winding).
Running an indicator on the machine and it is true on all axis, and the manual dial set to .0001" actually is accurate everywhere checked. Since I ran this machine all those years ago, the spindle bearings are new, the x servo is new, y servo is rewound, has all new air solenoids, tool changer servo, and the list goes on. Mechanically, it's on-point.
So, this brings me to my dilemma. I don't want to dump a bunch of (more) money/time into it, and thought it might be with it to just manually controlling spindle speeds with an opt stop in the program to allow speed and tool changes, and it can at least be making me small batches and prototypes instead of just taking up space in the back of the shop. After all the work gone into it, hate to part it out at this point (specially how true the thing is).
Seeing it's a 0-240v DC motor, is there an easy way to step down voltage? And being such a high DC current, is it even economical to step down the voltage after the spindle drive? Should I think about using a large 3ph motor and speed controller, pirating the spindle pulleys?
I looked into using a DC speed controller, but again, it's starting to get to expensive. I have eves and weekend to piddle with it, so time is easier to come by than large cash sums. Already invested too much recently upgrading equipment, but having this running and a lesser-experienced operator running it can really help out the shop.
Thanks for reading,
-John
Thanks for reading,
-John
