gundog
Hot Rolled
- May 31, 2004
- Southwest Washington USA
I have a 97 Trak DPM mill with an AGE 3 controller. I am trying to start programing it using my Cad/Cam software made by Vectric. The Vectric software I use on my router table and have used it for 6 years the mill I have always programed using the conversational programing at the head. Vectric wrote me a post processor but it must have a small glitch. I tried to run a small drilling program consisting of 6 holes in .250 5052 Al plate. I drilled through the material in the program by .100" and peck drilled using 2 pecks.
The machine runs to each location requiring a drilled hole hesitates and moves to the next hole location never plunging to drill. I am not used to programing G code but I looked up all the codes and they seem right to me except maybe it is missing the command for a drilling cycle 83. I will post this code and a note from the guy at SWI about what codes the control can take. I am hoping to get this working because I have more parts to make that would take a long time to program at the controller.
The code.
Proto Track Post processor drilling path that did not plunge to drill.
:1248
N20G40G80G20G90
N30T1M6
N40G0X0.0000Y0.0000Z0.8000S2500M3
N50G0X0.3000Y1.9000Z0.2000
N60G1Z-0.1750F3.0
N70G0Z0.0000
N80G1Z-0.3500F3.0
N90G0Z0.2000
N100G0Y3.8500
N110G1Z-0.1750F3.0
N120G0Z0.0000
N130G1Z-0.3500F3.0
N140G0Z0.2000
N150G0Y5.7900
N160G1Z-0.1750F3.0
N170G0Z0.0000
N180G1Z-0.3500F3.0
N190G0Z0.2000
N200G0Y7.7250
N210G1Z-0.1750F3.0
N220G0Z0.0000
N230G1Z-0.3500F3.0
N240G0Z0.2000
N250G0X6.7845Y0.5000
N260G1Z-0.1750F3.0
N270G0Z0.0000
N280G1Z-0.3500F3.0
N290G0Z0.2000
N300G0X5.5345Y0.5000
N310G1Z-0.1750F3.0
N320G0Z0.0000
N330G1Z-0.3500F3.0
N340G0Z0.2000
N350G0Z0.8000
N360G0X0.0000Y0.0000
N370M2
The note from Joseph @ SWI
The list of accepted G code are as follows
G0
G1
G2 & 3
G20 & 21
G40, 41 & 42
G73 Peck drilling cycle
G80 Drilling cycle cancel
G81 Drilling cycle, spot boring
G82 Drilling cycle, counter boring
G83 Peck drilling cycle
G85 Boring cycle
G89 Boring cycle, dwell at bottom
G90 & 91
M Codes
M0, 2, 5, 6, 7, 8, 9, 12 & 20. All other M codes are simply ignored.
Thank you for any help you can offer.
Mike
The code.
:1248
N20G40G80G20G90
N30T1M6
N60G1Z-0.1750F3.0
N70G0Z0.0000
N80G1Z-0.3500F3.0
N90G0Z0.2000
N100G0Y3.8500
N110G1Z-0.1750F3.0
N120G0Z0.0000
N130G1Z-0.3500F3.0
N140G0Z0.2000
N150G0Y5.7900
N160G1Z-0.1750F3.0
N170G0Z0.0000
N180G1Z-0.3500F3.0
N190G0Z0.2000
N200G0Y7.7250
N210G1Z-0.1750F3.0
N220G0Z0.0000
N230G1Z-0.3500F3.0
N240G0Z0.2000
N260G1Z-0.1750F3.0
N270G0Z0.0000
N280G1Z-0.3500F3.0
N290G0Z0.2000
N310G1Z-0.1750F3.0
N320G0Z0.0000
N330G1Z-0.3500F3.0
N340G0Z0.2000
N350G0Z0.8000
N370M2
G0
G1
G2 & 3
G20 & 21
G40, 41 & 42
G85 Boring cycle
G90 & 91
M Codes
Mike
