Ghoastrider
- May 27, 2012
- Columbus Mississippi
I just purchased a used Daewoo 200B Lynx 1999 with FANUC 21-T controller. It has a parts catcher. I checked and it looks to be pneumatically operated. I was able to see the Pneumatic valve block in the drive belts access cover of the machine. There was no regulator. It looked like you just screw in a NPT fitting and attach an air hose. Is this correct or do you need a regulator? If you do need a regulator does anyone know the set pressure in PSI? I'd like to plumb this and get the parts catcher operational. Thanks in advance.
