Nerdlinger
Stainless
- Aug 10, 2013
- Chicago, IL
Hi Everyone!
Please see the attached picture. I am facing two sides of this annealed 4140 being held in a vice. The part is 7/8" tall X 1-3/8" wide X 2" long. The face sticking out the side of the vice is faced with a 1/2" em at 100 ipm and the surface finish is good...maybe 30Ra". The top, however, is faced with a 1-1/2" face mill at 26ipm (about .004" ipt) and the surface finish is more like 150Ra" or so. I am looking for something like a 60 Ra".
I am using an Iscar four-insert HOF face mill with "general purpose" face milling inserts (the only ones available for this cutter, apparently.) The machine is a dual contact Speedio in good shape. I am only taking off about .007" and I see the machine mark swirls going both ways, which I think means the spindle is very perpendicular to the axis movement during that op.
I was going to try getting a face mill body that can accommodate a wiper insert. I have heard they can handle 2X the "normal" feed rate of the roughing cut, so maybe I could go TWICE as fast yet achieve the target surface roughness. I was also wondering if I should try zipping over it with the 1/2" end mill...since it's so much smaller than the face mill it would use higher RPMs and thusly higher ipm...plus maybe I could use one with like a .060" corner radius to help with the finish?
Soooooo, here's my questions:
1. Can anyone recommend a 1-1/2 to 2" face mill that would accommodate a wiper insert...that is, if the stories are true regarding feed rate and surface roughness.
2. Does it make sense to try using the bottom of an end mill instead?
Thank you!
Thank you!
