DavidScott
- Jul 11, 2012
- Washington
It shut off, no alarms, while raising the head to do a tool change. Control was off and would not come back on. I shut it off, opened up the back cabinet, and powered it back on. The control would still not come on and I noticed the 24 volt alarm light was on on the power supply. This is on a 2001 Kitamura with a Yasnac J300 control. I have a 1996 Enshu with a J50 control with what I think is the same power supply in case that helps. I have 3 photos showing the two power supplies and the alarm on the one. I don't know much about electronics but generally know enough to not cause more trouble. What should I do? Unplug all wires from the alarmed out supply except for the control wires and see if it clears the alarm. If so then figure out which connector is the problem? Thanks for any help.
