Help with Machining / Threading / Tapping
I need to manufacture a component from Mild Steel Bright Bars. I've enclosed the drawing herewith. While the machining tolerances are pretty wide the main criteria is roundness (on OD & ID) with reference to the thread.
Current process is
1) Cutting on Bandsaw
2) Drilling required hole on conventional machines
3) Machining ID 21mm, Small Face & Champher on CNC Lathe using a Hydraulic 3 Jaw Chuck
4) Machining rest of the area along with thread using a Tap on a CNC Lathe using Expanding Mandrel to Clamp the bore machined in previous setup.
While there is almost no ovality on ID or OD when checked on a mechanical comparator. When I check it after fastening it on a screw it shows random ovality of 0.1 to 0.25mm where as the acceptable tolerance is 0.15mm.
Please guide me what to do to get the component in required tolerance.
Current process is
