sidetrack50
- Jul 1, 2014
- Indiana
Well I guess my machine works ok but I definitely need help programming. Can you guys look this over and see where I'm going wrong. The program works up to block 10 where it mills straight to Y 4.8125 after milling the circle but when it goes to X 5.375 it goes rogue and mills straight while making a small curve at the end, ends up at X 5.660, tried changing things but it doesn't help.
