Help with program
sidetrack50
Jul 1, 2014
Indiana
Well I guess my machine works ok but I definitely need help programming. Can you guys look this over and see where I'm going wrong. The program works up to block 10 where it mills straight to Y 4.8125 after milling the circle but when it goes to X 5.375 it goes rogue and mills straight while making a small curve at the end, ends up at X 5.660, tried changing things but it doesn't help.
Can you post a shot of the actual program on the machine screen. And whats in D8? Most people probably wouldn't call g41 D8 at the first position call, but I'm not sure that's your problem.
D8 is the cutter comp for tool 8 which is dia .570, here's the program on the machine.
Its N10 you've called D8 Twice without canceling it the first time for one. Remove E1, D8,G41,G90 from your N10 line and you should be good. You should have a safety line at the beginning of each tool IMHO That .contains G80 G90 G40 at least
Hers a sample Fadal program for you. Maybe you can get some pointers from it.
  • SAMPLE.DOC
I don't see the G1 in N7 or the G2 in N9...
The X5.66 endpoint is correct- G41 is still active and the next move in N12 is the Y move to 3.1875. The endpoint of X5.375 has 1/2 of .570 added to it, which puts the center of the spindle at X5.66. The little arc at the end of N11 is just the control swinging a .285" radius around the corner.
You don't need to add more info. get rid of the E1, D8, G41 and G90 at line N10.
The X5.66 endpoint is correct- G41 is still active and the next move in N12 is the Y move to 3.1875. The endpoint of X5.375 has 1/2 of .570 added to it, which puts the center of the spindle at X5.66. The little arc is just the control swinging a .285" radius around the tool radius.
He has G2 at N9, But your right he does need a G1 at N7
Oh, you're right- it's at the end,lol.
Not the way I write my progs, but it's not a rogue machine- the moves are correct for a value of .570 in the D8 register. If the OP single blocked through, he would see the same shifts on the other end points.
Ok, this works perfectly up to line 11, it mills the circle then moves to Y4.8125 then moves to X 5.375 but has the curve at the end, it should stop at the X position then go straight to Y 3.1875
Um, no. It will feed a line to X5.375, then swing a .285" radius around that point (X5.375 Y4.8125). Then it will feed straight down to Y3.1875 with the center of the spindle at X5.66. This puts the edge of the tool at X5.375, which is what you are asking it to do.
Are you actually cutting a part? Or your just seeing the arc by watching the control?
HaHa....not a rogue machine just that last move at N11, it should be millng straight lines until the next part where it goes into another circle.I have 6 straight moves after the first circle.
Doesn't G1 cancel the G2, I'm .100 above the part checking its path before I cut
Yes but your in G41 with a comp number entered. So the machine is comping like it should. Drop your tool down and skate .005 off that part and see what you get.
The program looks good to me at this point. I'm not there so I can't see what your seeing. Is it swinging a BIG radius? Best thing to do is to drop the cutter down and just kiss the top of the part. See what the cut pattern looks like.
It still does the same and if I go to line 12 it makes a small half circle
It makes about a .5 radius, is there something I should use to stop the g2 code cause its making radius's.
