I have never really used a side mill cutter before and could use a little information. I have to remove a 3/16 radius around a bend in a corner on a low carbon steel. To do so I have to side mill cut around the bend. I could use suggestions. I need to decide if a staggered tooth cutter or straight tooth cutter would be better, how many teeth and what speed and feed. It will be 3" diameter and 1/4 wide cutter.
