Help translating German?
Results 1 to 10 of 10
    Jan 2004
    Chicago, IL
    188
    7
    Default Help translating German?
    Can anyone help with this drawing?
    I understand the tolerances and surface finish.
    I'm trying to find the material, heat treat and plating as well as any other notes that might be significant.
    Thanks!
    Apr 2006
    Denmark
    467
    1797
    112
    I think I might help you out but the letters are not readable, at least for these old eyes. Sorry.
    fusker
    May 2017
    Minnesota
    1,689
    2187
    1117
    Have you tried Google Translate?
    Sep 2007
    Washington
    5,623
    263
    1847
    Unless it's buried in the small print that I can't make out, or behind the redactions, I don't think there is a material callout.
    Regards.
    Mike
    Nov 2014
    Colorado
    3,662
    4097
    1066
    Quote Originally Posted by Flash Gordon View Post
    Thanks!
    Claims to be a "Stop-block" for a 50 taper HAAS spindle.
    Bottom left box mainly concerns heat treatment rules / cautions.
    Basically saying that thin walled areas (through) hardening is not allowed.
    When applying hardening / "Application hardening" * (possibly case hardening) the following areas have to be covered to prevent "Charring" = carburization
    - "Pass spring" / Spring pass areas = Keyways...
    - Threads or threaded regions.
    - Thin walled areas being defined for wall thicknesses < 4 (degree) Eht <--- Not sure what that really means. 4th degree ?
    ____________________
    In the box / labeled for material it is left BLANK, but trying to find relevant DIN / ISO numbers for applicable steels ?
    2nd table / box from the left might have incomplete entries.
    So for Surface treatment it states - Without / None.
    And then in a slightly contradictory way [To the box on the far left (bottom) ] - says for Heat treatment - Without / None.
    Maybe the material leans more to ductile iron /(toughened steels) vs hardened tool steels ???
    If I am able to squint/ decipher / correct anything else I'll put it here : fixed Keyway and Carburization +*
    __________________________________________________ __________________________
    Sorry that's a little vague as my machining / German technical dictionary is in a box 400 miles away from where I am currently.
    Usual disclaimers apply for rando info on the forum / web.
    Sep 2006
    Middletown, PA
    505
    182
    87
    As mentioned, try Google Translate. You can use your phone camera to focus on the text and it will automatically show the translated text. It seems to go thru some iterations of context until it settles down, so I use it with caution.
    Jun 2015
    CROATIA
    10
    8
    Material is EN 1.7131, or DIN 16MnCr5, or your AISI 5S59, it is written in upper right corner...
    In lower right corner its written, according to Google translate:
    Heat treatment advice: Hardening of thin-walled areas is not permitted. During case hardening, the following areas must be protected against carburization by covering
    Thread of keyways
    Thin-walled areas with wall thicknesses <4 "Eht
  8. Likes cameraman, Finegrain liked this post
  9. #8
    Mar 2012
    Geilenkirchen, Germany
    2,753
    1587
    1422
    Technical German is a nightmare. It is a completely different language than spoken German and Google translate doesn't ever work. The vocabulary seems to be known only to tradesmen in that specific trade.I live here and I run into this dilemma daily. If you know the name in English, it often works to first translate to Dutch or Italian and then into German. On the original query, zone hardening in Europe is very popular, especially when using the DIN equivalent of 4140, but in this case I don't think the cautions relate to this part specifically and just generic. I see no call out for material or heat treatment or surface treatment. If it were me, I'd make it out of 4140 and be done with it.
  10. Likes cameraman liked this post
  11. #9
    Jan 2004
    Chicago, IL
    188
    7
    Thanks to everyone! That gives me the info I need.
  12. #10
    Nov 2014
    Colorado
    3,662
    4097
    1066
    Quote Originally Posted by steve-l View Post
    That was my impression too,[Generic boiler plate of cautions as you say ] @steve-l in the bottom left box / table (when you rotate the posted image anti-clockwise.). Good tip about mapping into Dutch or Italian first then cash-out in English.
    Kinda bummed I packed my old technical German to English machining book into box thinking "Well I'm not gonna need that for a while " lol.
    I'm still not seeing @Locker's "Material is EN 1.7131, or DIN 16MnCr5, or your AISI 5S59, it is written in upper right corner..."
    Maybe I squint at it later :-)
    I dare say the text that's been blacked out with magic marker could also be legible -
