Hey everyone,
I'm working on dialing in a very well used Daewoo Puma 250 from 1998. I got the turret face perpendicular to the Z axis within spec, and test cuts on bar stock over 8 inches show a total taper of .0008. The taper will have to be good enough, because there is no way I can get a breaker bar on 2 of the bolts fastening the headstock.
This brings me to the problem of it cutting above center by about .008. I swept tool holder bores and also did some test facing to determine that value. From what I've been reading, and hopefully understanding, is that the turret is rotational offset to cause the above center cutting. However, when I sweep the stick hold flats on the turret for the tool in the cutting position, the indicator is spot on showing that it is flat to the x axis..... Correct me if I'm wrong, but this means the entire of the turret rotational axis is too high off of the bed/saddle plate, right? How do I deal with that, or am I misunderstanding something (VERY possible!)
If I do have to get into the turret, I know I'll have issues getting the 'locating disc' off of the turret face to get to the fasteners and locating pin holes behind it. Any tricks to getting it out, should I need to go that direction to fix my off-center cutting problem?
Thank you!
Thank you!
