Hi, I run a small makerspace, and we have a used OMAX 2652 that we have been using for the last few years with only minor problems that we have been able to fix (We're a handy bunch). Recently though, a user had a problem with the machine, and I haven't been able to figure out what's wrong. We've been down for several months and OMAX won't give us any troubleshooting info unless we pay them $5000 for their service plan. That's more than all of our other yearly expenses combined so I'm hoping you can help me instead.
The problem is an unspecified fault that prevents the head from moving and no other info is given. Previously we discovered that this happens when there is not enough air pressure to trip the pressure sensor, but I've checked every limit switch and the pressure switch (they are all wired in series in a big loop) for continuity and function. As far as I can tell nothing there is triggering the fault.
Is there something else I should check?
The current version of the OMAX software we have is version 19, the latest that runs on windows 2000 that the machine came from. I suspect that later versions of the software will just tell me what the error is instead of just saying "fault" and refusing to work. For some reason I can't find a later version anywhere.
I've re-installed their software several times, flashed the firmware on the controller, and checked everything I can think of. I'm about to just build my own control box to bypass all this vendor lock in.
[email protected]
[email protected]
