Here is an interesting approach
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Feb 2020
    Alabama
    366
    151
    104
    Jun 2019
    794
    348
    872
    I mean if you really need to do it for a job and have no other way I guess, but damn that still makes me pucker up seeing that. If you have a part you run regularly that needs that, buy a machine that can do it properly.
  3. Likes empwoer, mhajicek liked this post
    Feb 2005
    9,701
    16506
    11850
    Did you notice that the part is on a 4th axis? Not a 3 axis machine.
    Just nit-picking. That is pretty cool, though I can't imagine it
    being dead nuts accurate. Probably a bit of trial and error before
    you get it right, in other words, lots of setup pieces.
    Whats it cost? Doesn't look that hard to make. A lovejoy on a spring.
    Dec 2009
    Louisiana
    536
    202
    317
    boy that's neat but somehow uncomfortable to watch. The description said valve block - I could see this being useful in situations where you just need fluid or gas communication or just vent holes - ie - when accuracy isn't all that important.
    Jul 2006
    Hillsboro, New Hampshire
    13,624
    2995
    9123
    Interesting. I'm sure I came across a video like that before 2019, but can't pin down when. The spring must be in the lower section, even with that relatively long/thin drill I didn't notice any bowing of the drill itself.
    My only complaint? That they didn't program a speedier return to vertical after the hole was completed. I can see not wanting to rapid to it, or doing it while the drill is turning (especially not that), but 300-500ipm should be fine.
    Feb 2007
    Aberdeen, UK
    4,615
    1687
    2181
    Quote Originally Posted by Bobw View Post
    It would need a fixed centre of rotation joint in order to be able to hold the angle and position with anything close to enough accuracy to actually drill a hole.
    A Birfield/Rzeppa type constant velocity joint is probably what's in there.
  8. Likes woodchuckNJ liked this post
  9. #7
    Nov 2005
    Illinois
    2,281
    247
    2206
    I have one. I am distributor for them. Never got around to making a video for the website.
    Back in the day I used to make a lot of valve bodies for Hill-Rohm hospital beds. I would of given my left nut for one of these. Not every angled hole is +-.001 in position.
  10. #8
    Feb 2008
    MI, USA
    1,000
    72
    423
    Quote Originally Posted by fmari --MariTool- View Post
    Can you add that to the description on your site?
  11. #9
    Jan 2007
    Flushing/Flint, Michigan
    10,578
    619
    8547
    I have one. ....
    What do you use it for?
    Do you spot the start hole straight so that it will tip so nicely? What kind of spot? Ball, slot, cdrill?
    .375 drill?
    For sure a niffy tool to have in the box.
    Offset 45 max?
    Bob
  12. #10
    Nov 2005
    Illinois
    2,281
    247
    2206
    Unit is brand new. I ordered one for stock. So once I have it online I have at least one in stock.
    Yep, will put left nut in the bullet points, :-).
  13. Likes mhajicek, Ox, Bobw, Chris59 liked this post
  14. #11
    Nov 2005
    Illinois
    2,281
    247
    2206
    Around $700 each.
    This unit takes ER16 so .437 max dia if you use our oversized ER16 collet.
  15. #12
    Oct 2009
    Oregon
    6,156
    6594
    3487
    I wouldn't have thought a regular old cross universal joint would be in there. Keeps it simple I guess.
  16. Likes woodchuckNJ liked this post
  17. #13
    Feb 2020
    Alabama
    366
    151
    104
    Please make a video.
  18. #14
    Jul 2006
    13,624
    2995
    9123
    Quote Originally Posted by Garwood View Post
    That's what it looks like from the picture Frank posted.
  19. #15
    Nov 2015
    Colorado
    386
    63
    196
    This looks uncomfortable.
    Kinda grotesque! But pretty cool that it works
  20. #16
    Feb 2012
    1,621
    991
    1839
    Totally overengineered.
    Just do dis:
  21. #17
    Aug 2005
    CT
    8,366
    457
    2231
    Quote Originally Posted by gregormarwick View Post
    I am guessing that both upper an lower has a spring to allow the joint to extend, and holding the angle accurate is in the tricky upper/lower housing mating point.
    BUT!
    How is the programming done?
    It's gotta be with a Macro, as the side movement distance and then the subsequent pecking "angle" calculation is deadly dependent on the length of the tool.
  22. #18
    Feb 2007
    Aberdeen, UK
    4,615
    1687
    2181
    Quote Originally Posted by SeymourDumore View Post
    BUT!
    Presumably, both shafts are solid with the coupling providing the fixed centre of rotation, and there is a spring loaded sliding sleeve on one side of the coupling. From Frank's photos it looks like the sliding sleeve is on the collet side, and shank side is solid.
    Programming would be the same as with an angle head, except for the engage and disengage moves which would be a calculated radius perpendicular to the axis of the hole.
  23. #19
    Oct 2005
    22,051
    Been done for years in the field with much larger L:d ratios....."directional well drilling"...
    Also "directional boring" for underground utilities, with electronics in the drill tip/head to steer it.
  24. Likes CORONA VIRUS liked this post
  25. #20
    Aug 2005
    CT
    8,366
    457
    2231
    Hmm ... Dunno.
    Unless I'm missing something, both members of the "CV-joint" has to slide in order to allow the common contact point of the upper and lower outer sleeves.
    Never programmed an angle head, but now that I'm thinking about it, the programming should be the same, but that still does not solve my problem
    of figuring out how it's calculated?
  26. Likes Bobw liked this post
