Hermle UWF 801 won´t shift into highest gear + gross possitioning error
Likes Likes:  0
Results 1 to 1 of 1
    Jan 2018
    DENMARK
    Default Hermle UWF 801 won´t shift into highest gear + gross possitioning error
    Hello.
    I have a Hermle UWF 801 with a TNC 135 control on it. It has 50-2500 rpm spindle speed.
    When I try to select or program the 2500 rpm gear I get the "incorrect spindlespeed" error.
    I have tried to acces the parameters to check if they are correct.
    But following the instructions in the Heidenhain manual doesn´t work. No dialog appears just a blank screen.
    I allso occationaly get the gross possitioning error when rapid traversing the X axis longer distances. Haven´t occured on the other axes/axis?.
    Can anyone help me troubleshoot and fix these issues? I´m not a complete moron at troubleshooting, but I havent got any experience with software issues.
    I have attached photos of Machine number, gear selections, ID and program numbers of the TNC, front of the PLC and one of the feed motor.
    I hope I have provided enough information.
    Best regards
    Kasper Elbak.
    Attached Thumbnails Attached Thumbnails 20210302_100918.jpg   20210302_100740.jpg   20210302_101049.jpg   20210302_104811.jpg   20210302_105036.jpg
