YouTube
Start at 12 minutes. Not the exact cutter, and they show it mounted on an anti-vibration toolholder.
(Extremely expensive, and not necessary with high-feed mills unless you have a really weak machine, or a very flimsy part, such as a weldment...) Nonetheless, it shows off what a high-feed mill should be capable of. If you have a rigid machine & setup, you should be able to exceed that performance, even at that length without issue.
This is the previously mentioned Seco 218.19 high feed mill. It's an older design, but still a fantastic performer that's tough to beat.
Cutter Body
https://www.mscdirect.com/product/d...&pxno=70383630&refnum=70383630&rItem=44497949
Inserts
https://www.mscdirect.com/product/details/65946550?rItem=65946550
Also, for what it's worth, I've never been a fan of square insert high-feed insert tools. This may be blind, unfounded opinion, but I've never found these tools to be anything but abusive. My not so extensive experience leads me to believe that trigon & parallelogram inserts that have rounded cutting edges are much easier on the machines. I'd like to believe that it's the rounded cutting edge in concert with a slight helix on the edge, that eases the insert in & out of the cut.
At any rate, there's lots to choose from. Seco, Iscar, Ingersoll all have lots to choose from. Tungaloy seems to be growing in high feed mills as well.
