High speed machining aluminum... An open discussion.
Page 1 of 2 12 LastLast
Results 1 to 20 of 40
    Jul 2018
    95
    14
    19
    Default High speed machining aluminum... An open discussion.
    My go to feeds and speeds for roughing aluminum are... Sometimes I push, sometimes not, but this is my starting point.
    1/2 3 flute end mill
    2020 sfpm ( 15,432 rpm)
    .008 chip load (feed 370)
    20% step over (.100)
    200% axial depth (1.000) max
    I was talking to a pretty experienced guy a while back who told me he was regularly at 800 inches per minute. Which got me wondering "what does he know that I don't?"
    I've concluded that either he was trying to impress me with some Titan type numbers or his stepover is 10% or less, in which case what's the point? 800 ipm at 10% or 400 @ 20.
    So, what is everyone else's go to high speed parameters? Discuss!
  2. Likes frank Texas liked this post
  3. #2
    Sep 2007
    Washington
    5,057
    160
    1417
    BT30 spindle (not dual-contact)
    3/8" or 1/2" 3-flute
    16,000 RPM
    288 IPM (.006" chipload)
    35% stepover
    Up to 1" axial for 3/8", 1-1/4" for 1/2"
    I'm very happy with these parameters. Roughing is usually only like 10% of my cycle times so I spend a lot more time optimizing and tuning elsewhere.
    Regards.
    Mike
  4. Likes BRIAN.T, barbter, frank Texas liked this post
  5. #3
    Jul 2018
    95
    14
    19
    Quote Originally Posted by Finegrain View Post
    16,000 RPM
    35% stepover
    Regards.
    Mike
    That's great, and those are wildly different numbers then mine. I knew this would be interesting. Thanks
  6. #4
    Jul 2012
    Washington
    2,442
    952
    992
    Depends on what you are roughing with. Corncob mills will put you in a different state as far as chip loads go. 3/8" mills are .01"- .035" per tooth, and those are just for starters. Almost always I can't hold onto my parts well enough to even start to push the endmill, bummer.
  7. Likes BRIAN.T, StirlingMachine liked this post
  8. #5
    May 2004
    2,493
    885
    1611
    One can program 370 or 800 inches per minute, but does one actually receive what one asked for? One thinks likely not.
  9. Likes Larry Dickman, dstryr, AARONT liked this post
  10. #6
    Dec 2014
    CANADA
    British Columbia
    1,207
    347
    563
    Quote Originally Posted by [email protected] View Post
    They sure do if the guy runs it in dry run. I’ve solved that problem for my guys more than once
  11. Likes Mtndew liked this post
  12. #7
    Mar 2013
    Oregon
    1,630
    686
    1856
  13. #8
    Nov 2007
    Alabama
    1,488
    177
    261
    Quote Originally Posted by BRIAN.T View Post
    So many variables.. tool, spindle, fixturing, etc. I think your numbers are just fine.
    If your spindle is happy and the part stays in the vise all is good.
    The real question: Are you making good money at these parameters? If so, you're golden.
  14. Likes frank Texas liked this post
  15. #9
    Jul 2018
    95
    14
    19
    Quote Originally Posted by Hazzert View Post
    I'm sure he is referring to the machines ability to accelerate.
    As for acc/Dec my 3 axis mills (which are all the same) have a Max feed rate of 370, which I have no problem achieving with the correct Gcode. Without the high speed codes in place the mills only get up to about 200ipm. My 5 axis tops out at about 1200ipm. I've never tried anything above about 500ipm. But ide be inclined to agree that people who program at outrageous feeds rarely see those numbers in practice.
  16. Likes frank Texas liked this post
  17. #10
    Jul 2018
    95
    14
    19
    Quote Originally Posted by exkenna View Post
    Yeah you are absolutely right. My cat40 (single contact...? Is that the opposite of dual contact) don't always love those numbers. My HSK spindle, sounds like I'm cutting air. Hsk is a beautiful thing.
  18. #11
    Jul 2018
    95
    14
    19
    Quote Originally Posted by gkoenig View Post
    Ahhhhhb so good! Thanks man! Shit made my day.
  19. #12
    Feb 2009
    Midwestern MN/Wi USA
    1,313
    73
    357
    20 percent is aggressive but that chipload is light. .010 to .015 with a 15 to 18 percent stepover. If the material is held rigidly I dont think your numbers are too far off. If you have the drawbar force and taper for it double that chip load. Most aluminums are just butter needing to be peeled off
  20. Likes BRIAN.T liked this post
  21. #13
    Nov 2014
    Florida
    2,606
    1267
    1262
    Quote Originally Posted by DavidScott View Post
    That is my problem. We do sooo much variety, but most of it ends up being held onto .05" in standard vise jaws. Yes, I know there are better ways to hold onto minimal stock, but we don't have it. Also, as someone else said, roughing is normally (for us anyways) about 5-10% of the time so I don;t see the point in pushing the rough balls out... I know there are other factors, but a big run for us would be 50 pieces too.
  22. Likes frank Texas liked this post
  23. #14
    Feb 2008
    MI, USA
    714
    54
    259
    I often have the same problem. And for most jobs, that is enough, don't try to hog it out super fast, and that is enough.
    For slightly better protection, when running steel only holding onto that much, I go with the talon grip jaws that bite in a bit. It is an obvious improvement, but also obviously only works if you are milling all around the part and can flip it.
    But lately, I am beginning to consider making my own dovetail soft jaws for those really pesky jobs that i only have a bit to hold onto and need a lot sticking out of the vise. I have a dovetail cutter and some dovetail jaws for the 5th axis vise, and because I see how securely those dovetails hold onto the part, I have a 3axis job on my desk here that I'm gonna dovetail first, because we had pullout issues on it before.
    As for speeds and feeds in aluminum, I only have 6000rpm on most machines, so for roughing applications, 6000rpm/150ipm/.25"stepover/1" deep.. I drop to 5000rpm/60ipm/.5" deep for full slotting applications, 1/2" endmill in 7075
    I am not breaking any records by any means, but gets the job done quick.
    Last edited by dandrummerman21; 04-16-2019 at 03:14 PM. Reason: wrote wrong feedrate duh.
  24. #15
    Jul 2018
    95
    14
    19
    Quote Originally Posted by Speedie View Post
    That is fascinating, you're approach is backwards from mine, though I definitely love the idea of less stepover with a larger chip, but again on my 3 axis I'm limited with my feeds. Im going to see what kind of chip.i can make on my 5 axis soon. Thanks.
  25. #16
    Jul 2018
    95
    14
    19
    Quote Originally Posted by dandrummerman21 View Post
    6000rpm/300ipm/.25"stepover/1" deep..
    Don't sell yourself short, that's a hell of a chip you're making. Is this cat40?
  26. Likes J Gilles liked this post
  27. #17
    Jul 2018
    95
    14
    19
    It took me about 2 years to convince the owner that more stock was well worth the extra money. Faster roughing, faster setups, far less error. When I started here we (they) would saw cut most parts to size then try to machine precision parts. It was embarrassing.
  28. #18
    Jan 2010
    Gilroy CA
    4,354
    3144
    2400
    I'd say your biggest improvements will be from increasing stepover by 5% increments until you find the limit. I have machines with 50hp but roughing tends to be such a small percentage of the overall cycle time for us most of the time. I usually find way more cycle time improvement by running multiple parts a cycle, reducing air cutting, moving to 4/5 flute aluminum finishing cutters. Only takes one chucked part or one broken tool to wipe out the savings of pushing away from process reliability and then it was all for nothing unless you are like Tony or Greg trying to run 10k parts a week and pushing for seconds in saving
  29. Likes DethloffMfg, exkenna liked this post
  30. #19
    Nov 2014
    Florida
    2,606
    1267
    1262
    I tried to 'sell' talon grips here... Oh well, it appears the agreement is 'fast enough' for roughing when it is such a small part of the machining process. With the odd standouts making a bazillion parts a year.
  31. #20
    Jul 2012
    Washington
    2,442
    952
    992
    I am doing more and more aluminum plates that have to be machined on all surfaces but I get to put a radius on the top, my design. This allows me to reduce the wasted material to a bare minimum but I only get to hold onto .03" to .05" of the part. I despise any waste and the quantities are in the thousands a year so any savings will add up, my designs so as long as they sell I will be making them. It's been a long time coming but I just made a small batch of steel wedge clamps and stops with teeth .015" apart to use in my fixtures. I have found that I only need to bite into the aluminum about .001"-.002" for it to hold. The difference between a smooth clamping surface and one with teeth is AMAZING!!!! So nice to go from babying the thing for fear the parts will pull out of the fixture to not giving it a thought cause they are not going to move, period!
