Hmc retaining parallels in a vise
Results 1 to 19 of 19
    Aug 2019
    South Dakota
    Default Hmc retaining parallels in a vise
    I'm looking for ideas to retain parallels in a vise tower in a horizontal mill. We're using hard jaws with parallels in a Kurt vise tower. We have plates bolted to the sides of the jaws to use as stops so parallel spreaders aren't going to work. The current idea is to use some good die springs with flat faces. I was just curious if anyone had any good ideas. We've used this set-up before and the problems we've had are chips getting under the parallels, springs getting dislodged and lost, things like that.
    Feb 2014
    Sunny South West Florida, USA
    3,098
    11139
    3501
    Drill some holes in the jaws. Epoxy in some neodymium magnets flush, or just shy of the surface.
  3. Likes rfan8312, as9100d liked this post
    Nov 2014
    Florida
    4,131
    1620
    1941
    Expensive, but they make some parallels for exactly what you need (in 1/8" increments or so)... Sorry not finding a good link. I think Teco (probably others too) makes some. The vise jaws have a littel pocket and the paralells have a spring like notch that locks them in place...
    QuickChange Parallel Kits On TE-CO
    Here they are. Might be cheaper to make once you see how it works, but for $400 time might be better for you.
  5. Likes rfan8312 liked this post
  6. #4
    Mar 2006
    PHILIPPINES
    2,598
    629
    960
    I take leftover metal banding material, cut with tin snips then bend in a "WV" shape to whatever the spacing is. Pallet banding material is spring steel so its perfect. I keep all the banding that comes in and have a collection of heights from 1/2" to 1-1/2".
  7. #5
    Nov 2012
    usa
    53
    8
    Like gcoder-05 said, I use this trick all the time. Old bandsaw blades work very well too.
    Sent from my Moto G (5) Plus using Tapatalk
  8. #6
    Jan 2017
    Oregon
    3,150
    630
    2180
    Been using the banding trick for 40 years, but sometimes it's just better to make some jaws and mill in the step. Hell of a lot easier to blow off and load parts than monkeying around with parallels all the time- specially on a horizontal...
  9. #7
    May 2017
    Minnesota
    1,155
    1459
    803
    Or use step jaws.
  10. #8
    Dec 2012
    Se Ma USA
    1,643
    126
    906
    Spacer block and a piece of polyurethane hose as a spring.
  11. #9
    Jun 2013
    Washington
    95
    17
    Go buy some modeling clay. Put a dabs between the jaws and the parallels. Put a block between and tighten down. Sticks rather well.
    Or just tighten down on the vise. Open it up, add material, clamp. Make chips.
  12. #10
    May 2015
    Tennessee
    202
    131
    79
    TBH step jaws sound like the answer. Steel jaws from Monster Jaws are pretty cheap, just add a step. If you're in a pinch then yep, bend some banding stock into a W or Z pattern and use it as a parallel keeper.
  13. #11
    Oct 2009
    Oregon
    4,580
    4934
    2373
    Quote Originally Posted by ss_user View Post
    I could fill a 5 gallon bucket with modeling clay from vises I have bought from Everett area aerospace companies over the past decade. You wouldn't happen to be in that area would you?
  14. Likes as9100d liked this post
  15. #12
    Apr 2019
    Arkansas
    1,031
    391
    374
    Quote Originally Posted by TeachMePlease View Post
    We make brass bushings for the magnets and then press it all together. No need for epoxy and the magnets don't magnetize everything around it.
    Sent from my Pixel 3 using Tapatalk
  16. #13
    Jun 2013
    Washington
    95
    17
    Quote Originally Posted by Garwood View Post
    Not quite; local? no but only 175 mi away. This was something I did entirely on my own. I'd like to say .. great minds ...
    More like even a blind pig finds an acorn once in a while.
  17. Likes Chris59, Garwood liked this post
  18. #14
    Jun 2012
    Michigan
    5,003
    4554
    3012
    Buy a big bag of decent size rubber bands, they will last you a couple of years.
  19. #15
    Feb 2014
    3,098
    11139
    3501
    Quote Originally Posted by as9100d View Post
    Brass makes sense. I know those coated magnets aren't going to compress without crumbling, so I figured for going right into steel, an epoxy fit was desirable over a a press fit. I imagine pressing into brass is no big deal.
  20. #16
    Apr 2019
    Arkansas
    1,031
    391
    374
    Either way works. Two of the best ideas came from us Hmc retaining parallels in a vise
  21. #17
    Mar 2012
    North Carolina
    403
    1217
    154
    I use rubber bands but some of the chemicals I spray on them eat them up. Then I will use zip ties and make a rectangular shaped design and tighten them. They last forever and i reuse them all the time.
  22. #18
    Sep 2010
    Oklahoma City, OK
    4,697
    808
    1937
    Quote Originally Posted by mhajicek View Post
    Or use step jaws.
    I'm kind surprised that a reversible step/non-step hard jaw hasn't been released. I guess one could pair and elongate the holes.
  23. #19
    May 2002
    South Central PA
    13,726
    2335
    3592
    There are 2 kinds from Teco, 1 snaps in and 1 slips in from the side. I have the snap in set, they are pretty nice.
    Quote Originally Posted by Cole2534 View Post
    There is, I have a set for 8" vises, I think Kurt made them.
    Quote Originally Posted by PegroProX440 View Post
    I've used truck tarp straps for serious holding power. Punch a new end hole where needed.
