I'm thinking about getting a 2001, out of service, Roku Roku Libero RX6 HMC. At this moment it is due for scrapping, pricing should be near scrap metal, and I contemplate about saving it.
I do have a 9-5 in the machining business, but this will be a hobby gig. Not sure were I will end up with it. If I won't fail the retrofit, I'll keep it as a white machine for black days. Who knows.
I do have my fare share of diy, and I do like wrenching so, it can't hurt a bit of play.
Main concern is my lack of knowledge via electrical/electronics part.
Either way, I do know what am I getting into.
Short machine description:
- very small footprint
- double pallet
- Nikken CNC-201 unit as the fourth axis
- 2.2KW 12 or 15000 rpm
- ISO 30 spindle
- 30 tools chain + shifter, index ATC
- Fanuc 18
- Small Fanuc aplha series servos (red caps)
- 40.000mm/min rapids
- roughly only 6 years in use
- though it was kept indoors, it wasn't prepaired for preservation. Few rusty dots on the guides, spindle was blocked etc
- all the amps, controls etc are missing. Though, I could recoup them from her sisters
For starters, I would wan't to avoid keeping her with Fanuc controller. I do like Fanuc, but for hobby use, I can't afford their service costs. A middle way it's impossible since it is way too proprietary.
My first priority is to make sure there is a solution for what I'm trying to do. At this point barriers that block my view are as follows:
- Peripheral stuff: pumps, brakes, pallet changer, doors, sensors, ATC, pneumatic valves etc. Should I govern them via macros in Mach4, go via a PLC or go the old school way of relays?
- I have Fanuc servos for the tool magazine and for the pallet changer. Do I need drives for these motors? or they can be driven directly via a PLC?
- Fanuc red caps - should I use a converter for the encoders? or just change the encoder?
- Controller would be CSMIO analog version. If I definitely need drives for the pallet changer/atc magazine servos, I'm thinking to replace these with steppers. This case would require the step/dir version of CSMIO
- HMI - heard the term Pokeys as a solution, or some other gadget from CS Labs that can do the trick. I'm looking for stable, 100% reliable analog controls. Example feed override.
- is Mach4 stable enough to keep things safe? 40m rapids can get dangerous
- anybody have experience with Nikken 4th axes? drives, motors etc
- not sure what holds the tight precision on these machines. Quality ball screws? or is there some serious mapping in the old controller?
Any advice is more than welcome,
M.
- double pallet
- ISO 30 spindle
- Fanuc 18
M.
