First time to possibly be machining Ti and hoping to get some tips on maintaining tight toleranced milled features.
The part I'm looking at is TI-10V-2FE-3AL. It has a thru hole with .5" of cutting depth and a milled boss .83" tall. Both the features are around .437 diameter with .0005/.0000 tolerances. Typically i would just run several spring passes with an endmill around these features to maintain that tolerance. Would that plan of attack work with Ti? Would rubbing be an issue on the spring passes? Thanks in advance!
